View Full Version : rusty tank -dipping/coating?
vanzuuk1
05-04-2005, 02:30 PM
I have a rusty steel motorcyle tank, surface rust inside.I want to send it somewhere to have it dipped and coated with something permanent so it wont rust in 5 years. I plan to respray it again so i dont care if the paint is destroyed.I have tryed the home methodes and they dont work-kreem, etc. any info would be appreciated. the tank is an odd shape with baffles so its tricky to coat without dipping. HELP!
protour_chevelle
05-04-2005, 03:14 PM
Get it acid dipped first, then hmm, not sure what to do as far as coating the inside...?
-Matt
vanzuuk1
05-04-2005, 03:57 PM
i know , its the coating part that seems to be difficult.
Andrew McBride
05-04-2005, 06:13 PM
I don't know if you have tryed this but taking the tank and throwing some rocks inside along with a solution like degreaser or gas or anything and then shake it up. This will help remove the rust. Another thing is taking a high pressure washer with high heat. I cleaned the tank on my 65 mustang that had 14 year old gas in it and it was as good as new when finished.
vanzuuk1
05-05-2005, 03:05 AM
Thanks Andrew but the tank has a strange shape with a baffle inside so that wont get the corners. I have owned the bike for twenty years and have done this several times, I want this to be the last time. I am even considering having an aluminum tank made but its a lot of money.
The rock method works great if you secure the tank in a cement mixer and leave it for an hour, by the way.
rb70383
05-10-2005, 12:42 AM
eastwoodco i think has a gas tanking coating system. Never used it though. I'll need to on my project when I get to it.
Spitfire44
05-10-2005, 11:34 AM
How about having it hot tanked? I've heard of people doing this with good success. I have used the POR15 tanking coating system with good success.
vanzuuk1
05-10-2005, 01:22 PM
That sound like exactly what i want, more details please!
rb70383
05-24-2005, 09:47 PM
http://www.eastwoodco.com/shopping/search/searchresultsmain.jsp?fresh=1&searchType=advanced&iMainCat=0&iSubCat=0&attribute14=0&attribute15=0&attribute16=0&RS=1&keyword=gas+tank
I believe any radiator shop can/should be able to hot dip a tank. I had the tank done in a 77 Cordoba, and then coated with a black gel like sustance. This shop did radiators and tanks. Worked good, no problems.
vanzuuk1
05-25-2005, 02:26 AM
I have called a few radiater shops and they dont have a coating that will resist gas.I have tried the do-at-home kits and I cant get the stuff to coat even, the tank has steps in it.All my friends have tried the kits also, its a short term solution.If you know of a shop that will hot tank and then coat it with something I will call them.thanks.
rb70383
05-30-2005, 03:17 AM
:hand:It was a couple yrs ago in FL. I dont know the name. Man sorry, If I did I would try to hook ya up.
