    Results 1 to 6 of 6
      Dec 2002
      New York
      Different size wheels in front vs rear i.e. 16F / 17R
      Was curious to know if anyone uses different size wheels in the front vs the rear - I am currently using 16x8 all around - but I am considering using 17x7 in the rear, and keeping the 16X8 in the front.
      Mar 2003
      Petaluma, CA
      15 and 16
      On my 62 Nova I am running 15X7 on the front and 16X8 in the rear. I went this way because of the difference in the fender opening front to rear (Well that and I was on a tight schedule/budget). I think when I pull the car apart again, I will do 17s and maybe 18s.
      -Jeremie
      (I LOVE this new board, uploading pics is easy!!)
      dennis68 Guest
      Running 16X8 in the front and 17X7 in the rear would make for a very strange handling beast. Why in the world would you want to run a narrower rim in the back?
      Houston, Tx
      I'm currently running a 16x8 front and 17x8 rear.
      Woudl like to switch to a 17 18 combo at some point.
      Drew H.
      Dec 2002
      New York
      The reason why I am asking - is because - I can get a good deal on 17x7 wheels and rubber for the rear - as my current rear which is 16x8 with a 4 in backspacing - disc brakes - stock 12 bolt leaf rear - NON rolled quarter lip - as such - on occassion the rear tires rub against the bottom of the quarter panel - the price it would cost me to buy two new 16X8 with a larger backspacing would be about the same as purchasing the two 17X7 with a 5 in BS. I was wondering from an appearance standpoint - if anyone else was running larger wheel sizes in the rear and smaller in the front - almost like a "hot rod" style.
      It can work...I would only do it if the rear was going to be wider....say 17x9.5. If I had the 17x7 choice I would stick with the 16x8 and massage the inner fender.
      bob
