    Results 1 to 7 of 7
      Jun 2009
      Central FL
      American Autowire Crimper?
      So the AAW kits need a specialty crimper, and I've been to every store around me and they have no idea what I'm talking about. A specialty shop I stopped at said its a few hundred dollar tool that requires a special order. Is this true? Why is this necessary?
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Aug 2008
      Pgh, PA
      I have no idea what crimper you're talking about. We installed an AAW Highway 15 harness in my car with no "special crimper".
      '66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
      Jun 2009
      Central FL
      Dan
      1968 Camaro v2
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Overkill, you'll be fine with a proper ratcheting terminal crimper for non insulated terminals. Cost: $20-$30.
      Jun 2009
      Central FL
      I had an electrician look it over and he told me needle nose pliers and a big ass set of pliers (not technical term, forgot what he called it) will work fine. Thanks guys.
      Dan
      1968 Camaro v2
      I think if your worried about it AAW has a lend program where you leave a deposit and they send you the crimper and when you return it you get your money back. If you keep it you loose your money. check it out.
      Aug 2008
      Pgh, PA
      Quote Originally Posted by Vicinity View Post
      It says: "The Master Crimper performs both the wire core and insulation crimp in a single action saving you from having to do them separately as you would when using any other crimp tool"
      Believe me. We wired every single wire on my car, including doing some interesting things like adding some double pole double throw relays and microswitches. Started with a shell that didn't have a single wire in it. NOTHING stock. Regular wiring tools will do you fine. Every one of my connections is also soldered. My advice is solder it and then don't worry.
