View Full Version : Power steering lines
wmhjr
05-22-2010, 06:30 AM
I've made all my own cooling, hydro clutch, fuel and brake lines. However, I have no experience really with making high pressure hydraulic lines for something like power steering. All of my lines are either hard or braided stainless. I've got what I think is kind of a cheesy power steering line kit I used from "Gotta Show" but I'm switching to AN. Does anybody have any recommendation on either making power steering lines or having a braided set made to my specs?
dhutton
05-22-2010, 07:02 AM
Aeroquip and Russell both sell braided high pressure PS rated hose and fittings that you can buy at Summit. I used the Russell. It was a bit of PITA to assembled but no leaks. There are assembly instructions in the Russell catalog with all the needed part numbers etc.
eville
05-22-2010, 07:28 AM
I used this stuff...
http://www.summitracing.com/parts/AER-FCG0606/
The teflon braided stuff can be noisy.
here's a thread with some info...
https://www.pro-touring.com/forum/showthread.php?t=42656&highlight=aeroquip+high+pressure
JRouche
05-22-2010, 08:03 PM
Good info, looks like you did all the research. And that was two years ago, still holding strong? Sounds like thats the ticket. JR
wmhjr
05-23-2010, 06:20 AM
Thanks, Guys. I've noticed in the past that for example Fragola hose is more difficult to get ends on due to the heavier construction of the hose and braid then for example Russell. The Fragola hose certainly seems to be much "tougher" - though I also wouldn't necessarily call the Russell weak. Anybody else notice this?
Also, how would you guys compare the difficulty in assembling these hose ends as mentioned above to either normal -6 or-8 Fragola or Russell stuff?
JRouche
05-23-2010, 05:58 PM
I cant talk about the braided hose that you guys are using. I have only used the SS braid.
But what I do is grip the hose in the vise. Tight enough so it wont slip but not so tight that it deforms the end. With the plastic braid I dont think Id do it though, might hurt the braid. Then I use a socket that fits the nut. With the socket on the ratchet and nut in the socket I push as hard as I can, pushing the nut against the hose end and turn, left hand threads usually. It starts to tear up the braided end a lil, some crunching sounds. But I keep going. And the course thread screws on fast. If there is a loose wire or two dont stop, never stop LOL Keep the pressure on and thread the nut over the braid. And no matter how well I cut the braid, it seems like there will always be a stray wire or two that doesnt want to get under the nut. But thats just at the start of the threading, the loose wires will be covered up by the nut. Never had one sticking out after the nut is fully threaded. And I have tried to start over and reposition the strands of wire. It just turns into a bigger mess. I have to re-cut the end.
Once the nut is seated. Then the tube can be inserted and thread that into the nut. Make sure to keep the nut AND hose from spinning. And I dont use lube, never had to but they make it for this. Thread the end in all the way and its a tight fit. No need to go crazy for tightness on the last part. Just seat it to the nut and its secure.
Ok.... Solly. I know you didnt ask about how to make a hose end. I just felt like writing. :) Im sure you already have it down..
As for some hose ends being different? I have used them all. Cheapys from online (ebay) to higher (priced) quality ends. Cheap in money, not in quality, all US made. Although the anodizing does show the cost diff. And that does make a diff. Thats another discussion. Me removing all the anodized coating from some fittings because they wouldnt seal. Not hose ends but NPT fittings.
Solly for talking so much. Its just a topic that is current for me right now. Been dealing with a large (for me) air system, that has alot of AN fittings and hose ends. Been tracing down leaks for three days now and finally have it all buttoned up. NO LEAKS!!!!! JR
CarlC
05-23-2010, 06:22 PM
IMO teflon hose is significantly easier than standard AN end assembly. It will also likely last the life of the car vs. a neoprene or nitrile rubber.
I've never had an Aeroquip part leak or come apart, and there's a fair amount of hose and ends on the car. Off the top of my head there's at least 9 ends and close to 15' of hose. The nice thing about sticking with one manufacturer is that only one brand of replacement ferrules are needed.
67 455 Bird ragtop
05-24-2010, 04:37 AM
I'm likeing this stuff for all my hose applications. It's a little pricey but should last forever. Plus the Kevlar cover shouldn't spear your fingers during assembly like the stainless does. And it's more flexible than the stainless coating. It doesn't come in -3AN for brake lines so I'll have to use the stainless for that.
http://www.pegasusautoracing.com/productselection.asp?Product=3490
dipren443
05-24-2010, 05:03 AM
If you go with Aeroquip PTFE line, I have some fittings that may help you out... A few straight fittings and a few 90's. The 90's need new ferrules, but they are cheaper than buying fittings. Let me know if you need them and we can meet up one day after work.
Nick
dipren443
05-24-2010, 07:40 AM
Ooh, I like that. I am not a fan of the stainless look... May redo my lines.
AintQik
05-24-2010, 07:54 AM
I usually go to the closest heavy equiptment place and have them whip me out some. They carry almost every type of hose avaialble, braided, natural, AN, push on, and they know how to make stuff that won't break or leak. I do a lot of stuff myself, but I find this just to be the easiest way out most times. I just measure and go get a hose or two. On my P/S they even brazed the right ends on to mate an AGR box to an old GM pump. Worked great.
