Results 1 to 10 of 10
05-18-2010 #1
- Join Date
- Aug 2004
- Location
- Rockford, MN
- Posts
- 278
Where do I route the antenna wire on a '69 Camaro/Firebird?
I pulled the old mangled wire out a long time ago and am finally installing a stereo and replacing the antenna.
Where does the wire pass through from the mast to the interior?
There is a notch at the door seam, does it go there and get pinched behind the kick panel edging? Or is there a dedicated hole somewhere else that I can't see?
1969 Firebird, Black, Parchment Arizen interior, Poncho 383 (4" crank), Kauffman heads, TKO600, Moser 12 bolt, Wilwoods, DSE, Speed Tech, Koni, Hotchkis, GW, 18" TTI's, VA Gen IV, etc.
