View Full Version : ATS Steering Arm bolts
jocko124
05-09-2010, 04:17 PM
I just got the ATS spindles on my car. When I go to bolt on the steering arms I'm getting a lot of resistance with the bolt shank going through the arms. I can tap them in, but it seems they're tight enough that they would not turn easily. Am I missing something? Also, in the directions off ATS' website it says "Note that there are two
different length steer arm bolts with the longer of the two used in the rear." All 4 bolts I have are the same size. Anyone else experience any if these issues?
https://static1.pt-content.com/images/pt/2010/05/DSC_00015-1.jpg?t=1273450002
https://static1.pt-content.com/images/pt/2010/05/DSC_00023-1.jpg?t=1273450604
dhutton
05-09-2010, 04:22 PM
At least you got bolts with yours. Mine came with none. What a PITA, I have no idea what sizes are needed.
Don
jocko124
05-09-2010, 04:32 PM
It says H-K USA 1/2-20 on my bolt heads--hope that helps.
JRouche
05-09-2010, 06:06 PM
Thats good that they are tight. Various bolts have some thickness added due to the coating.
Are the arms steel or aluminum? If they are aluminum the anodizing may be causing the tightness. But more likely its the coating on the bolt.
It may just take a quick swipe with some 220 grit sandpaper on the smooth shank of the bolt to knock down any rough spots on the coating. Knock down the rough coating (black oxide coating can be rough) a lil and lube the shank up with oil. It will prolly turn just fine. You want the shank of the bolt TIGHT in the bore of the arm. They did a good job if its tight. The bolt shank just needs to be polished up a lil. JR
killer69
05-09-2010, 06:50 PM
all you have to do is call.
the bolts should be 1/2 x 2.5 and 2.75 NF socket head cap screws.with slim line locking nuts.
i don't know whae you ordered yours Don but all the spindles "Should" come with bolts. if you ordered the steering arms seperatly they would not have come with hardware.
currently we zinc plate the bolts,(i see yours are not) and that combined with the anodizing will cause a tigth fit. but that is good.
call if you have an issue
jocko124
05-09-2010, 07:04 PM
Thanks JRouche.
Blake, I'll talk to you tomorrow.
dhutton
05-10-2010, 06:23 AM
Blake, my spindles and arms were shipped just before the Speedtech buyout and as such I am pretty much on my own.
killer69
05-10-2010, 07:39 AM
why don't you give me a call i am sure we can fix you up!!
1-888-467-1625
dhutton
05-10-2010, 09:52 AM
1-888-467-1625
That is top notch customer service right there when you are taking care of someone else's customer. I will give you a call.
dhutton
05-11-2010, 02:31 PM
Spoke with Blake today. Great guy, he is sending me the steering arm bolts no charge.
Don
nor_cal_67rs
05-11-2010, 04:06 PM
I just looked at my ATS spindles that are still in the box and they didn't come with any bolts either...I bought them through Classic industries
killer69
05-12-2010, 07:00 AM
give me a call
John Wright
05-12-2010, 07:13 AM
WTG Blake.
Yelcamino
05-12-2010, 09:10 AM
Don
Now that right there will bring in new customers. Until I read this thread, I wasn't aware of Speed Tech Performance but I am now! I have a set of ATS spindles and steering arms I bought from Tyson just before he closed the doors so I'd have them when I wanted them not knowing they would be available through other dealers. Anyway, I think I might need some hardware as well. Now that I know there's a good source for hardware, I feel better. Thanks!
clu269
05-12-2010, 04:17 PM
Also mine were purchased from SCandC and did not have bolts shipped with them.
TT302Z28
05-12-2010, 04:37 PM
Hey...I got the bolts but no arms!:hammer:
Just kidding!
killer69
05-12-2010, 06:03 PM
WOW
it would "appear" the NO one got bolts!!!
if you need bolts you will have to call me and i will start a list.
TT302Z28. i don't know if i can HELP YOU........... lol
MonzaRacer
05-18-2010, 12:02 AM
UHMMM LAST I HEARD TT302Z28 WAS BEYOND HELP PERIOD! But thats just rumor too.
John Wright
05-18-2010, 05:15 AM
Just kidding!
No arms?....so...you're gonna need some help putting the bolts in? LOL
nor_cal_67rs
07-13-2010, 07:23 PM
Hey Blake I never received the bolts and was just wondering if they have been sent out yet... thanks again
mean buzzen half dozen
01-13-2017, 09:18 PM
Old thread, but are these aluminum steering arms still available? Price?
Thank you.
derekf
01-18-2017, 08:20 PM
Speedtech's website does still list the AFX spindles and the steering arms, at least for Chevelles.
dhutton
01-19-2017, 04:24 AM
Speedtech only has A body arms. They never made F body arms.
Don
