View Full Version : LS2 Vats ?
kochevy67
05-09-2010, 12:55 PM
Will a LS2 with the VATS not deactivated have spark to the motor or not. I am trying to start the car and was wondering if the car will start and run for a few seconds then die. Can you spray carb cleaner to see if it will fire? I still haven't had the computer programmed yet. I wanted to see if I have everything wired correctly first.
Thanks.
Mike Holleman
05-10-2010, 08:44 AM
Thanks.
I do not think the VATS will allow ignition unless all sensors are present and you are using the factory ignition switch. Call John at Speartech for an educated answer. 765-378-4908
Mike
kochevy67
05-13-2010, 08:52 PM
Had the ECM flashed and it is up and running. Hell yeah.
