View Full Version : Low cost wheels for a mini tub camaro... Options?
XLexusTech
05-08-2010, 06:30 AM
Looking for an inexpesive but nice option... think i might of found an option but I dont know what backspace..
Detials.. 67 camaro Mini Tubs.. Oem subframe with spc arms and ATS coil over conversion.
I al looking at these http://www.newstalgiawheel.com/wheel_detail.asp?subcat3=1011109
18 x 9.5 rear backspace..? Not a big lip fan.. like symaitry instead
17X 8 or 17x9.5 front? on oem frame... backspace?
I am open on tires but want the tires to tuck under the lip
gearheads78
05-08-2010, 06:59 AM
If you are mini-tubbing why not 11" rears? Also if you are willing to spend that much Intro's are not much more
XLexusTech
05-08-2010, 07:23 AM
Well I guess I should explain a few things... I am only mini tubbing because my shock towers and inner wheel wells were shot.
I really don't like the look of those big lipped almost pro street wheel tire combos that are populat on PT camaros
I do like the nastalgia road racing look.
Also I am going to be using a Protigy Bar / G link so I have the option of a longer housing as well.. its a bit or a science project but will be a bit differient the most.
So what i was looking at is those Cobra Rims which are only offered in 9,5 which I think will be pretty good. I may be able to get the low under the lip look I am looking for which is tougher on the 67/8 then on the 9
And I think 17 limits your tire options..?
LS1NOVA
05-08-2010, 08:28 AM
Vintage wheel works 17x8 and 11.
XLexusTech
05-08-2010, 09:18 AM
Backspacing? tire suggestions? based on my goals?
