View Full Version : Twin turbo engine upgrades?
mnm99
05-08-2010, 04:15 AM
Here's the deal. This winter I'm pulling my engine to install my 2 drains. A little info first. I built a custom twin turbo system with 2 Garrett t-60s, 2 44mm wastegates and all the right stuff. It's a STOCK GM 350 290hp crate engine 4 bolt mains with around 8:1 comp. The wastegates are set at 4-5lbs with the smallest springs. I'm pulling it to install a 6 QT oil pan and a Victor Jr manifold.
My future plan is to build a new all forged engine, BUT what could I do while it's out that won't cost a lot of money. Or should I just leave it as is?
Here's a pic of the system so far...
MrForce
05-08-2010, 08:28 AM
Since you have another one waiting, probably nothing. I would add an oil cooler, phenolic spacer/insulator for the carb, and a heat shield for the master cylinder to make it all more reliable.
mnm99
05-08-2010, 01:09 PM
Thanks. I'm wrapping all the downtubes so that should help the heat by the master. I can't add any spacers due to hood clearance. And I thought the 6QT pan would help with the oil temp. I'll look into the cooler though.
DeltaT
05-10-2010, 11:41 AM
Looks good. You could upgrade your heads now with the ones you plan to use on your forged motor, but maybe that's more than you planned to spend this time.
How's she run?
Jim
brianjw4
05-11-2010, 07:43 AM
One thing to consider is valve springs, stock springs will float (especially if they have some miles on them) and the motor will have a hard time holding boost.
You might be ok with your boost level since it's pretty low, but something to think about. Anything higher will definitely require HD springs.
tooshort
08-28-2010, 02:45 PM
I'am new to the turbos could someone point me in the right direction,i want to do a ls motor,may be 6.0 liter i'am planning on driving this car,but i would like to make at lease 800hp are more.So do i go with twins or single,and what size,and how much money i'am i looking to spend, may be a set up like he have thanks.
shmoov69
08-30-2010, 05:50 AM
Www.theturboforums.com
