View Full Version : POR15 Glisten PC ?
mnm99
05-06-2010, 03:53 PM
Anybody use this stuff? I'm looking to get a new intake manifold and want it to look nice. I have a few options and so far this looks the best. I don't want it to yellow if gas gets on it. The first one I was looking at was the Endurashine that cost around $350. I've read it yellows. The second is polished that cost $420. Big $$$. The last is a standard manifold that cost $199. (Victor Jr). Then I could coat it for $40.
http://www.por15.com/GLISTEN-PC/productinfo/GPCGG/
Happyfunballs
05-06-2010, 04:07 PM
I haven't used that particular product from POR, but I can tell you that the regular clear over unpolished aluminum will yellow and consequently look shatty.
mnm99
05-06-2010, 04:42 PM
What do you mean regular? This is a 2 part epoxy.
Rick Dorion
05-07-2010, 03:51 AM
I've used the Glisten PC with good results. No yellowing and durable.
mnm99
05-07-2010, 08:40 AM
Anyone know what size spray tip I should use?
Rick Dorion
05-07-2010, 01:38 PM
In my case I brushed it on and it flowed out. This was on a gas tank but the finish was very smooth.
amargari
05-08-2010, 03:37 PM
Off topic, but what is with this warning.
WARNING: THIS PRODUCT CONTAINS ETHYLBENZENE - A CHEMICAL KNOWN TO THE STATE OF CALIFORNIA TO CAUSE CANCER
Does this product only cause cancer in California. :)
732ndgen
05-09-2010, 07:44 AM
did this on my blue 73 and has not yellowed after 6 years and im going to do my friends and another this weak.
Happyfunballs
05-10-2010, 04:28 AM
POR has a regular clear topcoat(without catalyst) that is UV sensitive and will yellow out....even on a transmisson that never sees the sun.
mnm99
05-11-2010, 06:02 AM
Did it come out nice? Glossy? Did you brush or spray it on?
732ndgen
05-11-2010, 04:20 PM
it was glossy and I brushed it on,it came out smooth clear and glossy Im going to try to spray the next ones.I was going to order from summit again but the shiping was $9.99 so I called my locall paint store and they got it for me in 1 day.you can get it in gloss or flat.good luck (glisten is a 2 part system the clear and a hardner)
rrstroker71
05-12-2010, 04:36 PM
JUNK, powdercoat or use a good clear. That stuff will yellow in no time!
mnm99
05-14-2010, 12:41 AM
I called back POR15 and a new tech DID NOT recommend using it. He was concerned about the heat and yellowing. Well that leaves me a clear coat or polished manifold. I don't know.....
rrstroker71
05-14-2010, 04:08 PM
Powder coat!!!
mnm99
05-14-2010, 05:21 PM
Powder coat!!!
I heard that yellows too.
rrstroker71
05-16-2010, 04:19 PM
Never had that problem unless you have a gas leak issue. Been doing it for a couple years now.
rrstroker71
05-16-2010, 04:21 PM
Never had a problem unless you have a fuel leak. been doing it for a couple years now
