View Full Version : Project "She Devil"
tyoneal
05-04-2010, 10:56 PM
To all:
Finally, with the help of Ben Hermance, and Jake Parrott, I think we have enough of what we need to get the project started officially.
Concept/Story:
She's a natural beauty with graceful classic lines. Driven to Hell, to become a Devil on the, "Trans Am", Race Tracks of the Past. She continues Evolving through the Nurturing of Modern Performance Engineering, and the Harsh Environment of High Stress Competition.
"Bettie", as I've decided her pet name to be, is based on the Similarities these two share by way of Images I've seen, and the stories I've read of the famous Pin Up, "Bettie Page".
There were a number of things about this car that have been 30 years in the making. I had a 1969 Camaro in High School, and before I had finished with it, I had to sell it to go to College. I really needed the Money, and I was able to get $4800 for it to start College. That was in 1980, and a LOT of Money for a '69 Camaro back then.
Since then, Technology has taken a Quantum Leap forward in Aerodynamic Design, Chassis and Suspension Technology, and the Drivetrain Choices that are available. All this, and the "Pro Touring" building style being developed has made my goal to encompass as many of these developments as I could, while retaining a nice driving Street Legal Car.
This has become a Labor of Love, regardless of the industry Norms, and the Mainstream Accepted Trends it might upset.
Chassis and Suspension: JRS Apex C6 Front Subframe, DSE Subframe connectors, JRS Modified Lateral Dynamics 3-Link
The chassis is composed of one aftermarket front Subframe from Jakes Rod Shop. "JRS Apex C6 Subframe" It is connected via DSE Subframe connectors and a 12 point Roll Cage, to a very modified rear subframe. Two Firewalls, (One fore/One Aft)
Weight Jacks on all 4 Corners
The JRS Apex C6 Subframe Suspension will consist of upgraded C6 Corvette Components. The rear will be modified for a more performance oriented Lateral Dynamics 3 link Suspension.
Genesis Cockpit Adjustable Front and Rear Sway Bars
Front: Penske 8300 Double Adjustable Shocks
Rear: Spax Double Adjustable Shocks
DriveTrain: Mast Motorsports LS-3 427 SS, Keisler R/T-56 6 Speed Dogbox, Strange 9 inch Housing, Nodular Iron Center Section, Tru-Trac posi unit with 3.89:1 Gears
Car Exterior Cooling System(s):
Radiator Brand TBA, Fan Mark VIII
Oil Coolers for the Engine, Gear Box, and Rear End will be used to help components last with the Belly Pan
Front and Rear Brakes will be Ducted
Brakes:
Front: Wilwood 6 Pot Calipers, 13 inch two piece Rotors.
Rear: Wilwood 4 Pot Calipers with Parking Brake, 13 inch two piece Rotors
Wilwood: Proportioning Valve
Body and Modifications:
Body Year: A 1969 Camaro Base, with 1970 Camaro Top, and with the "A" Pillar leaned in an Additional + 4*. Hopefully this will Help clean up the Aerodynamics, and still use only parts that were being sold as "NEW" during the same year. (ie. Some 1969 Camaro's were sold into the Early part of the 1970 Year, as the 2nd Generation Camaro's were not ready yet with the newer Body Style. There were places that sold the second Generation Camaro's as the "1970 1/2" models, with the 1969 Models being sold initially as 1970 models.) Since this was the case, we took and blended the two years together to enhance Performance and Styling and to build a true 1970 1/2 Camaro.
Body Materials: Steel, Fiberglass, Carbon Fiber, Aluminum
Body Additions: Adjustable Dive Plane (Canards), Adjustable Splitter, Adjustable Spoiler, Diffusor
Lower Body Pan: Full Belly pan with wind vanes and Tunnels
Mirrors: Talbot 4 inch, Brushed Aluminum
Some Body Features will be altered or removable, depending on type of driving being done.
Due to using the Belly Pan, a number of Vents will be used to evacuate Hot Air out of the Engine Compartment. (Placement in Rendering is approximate location)
Will Try and Create a True "Ground Effects" car, By Shaping the Underside, and the Exterior for Decreased Lift and Wind Turbulence, and Increased Down force and Stability.
Tow Hooks Front and Rear
Interior:
Recaro Topline "Style" Seats. Full Leather with Heating and Cooling.
"Cool Suit" Hook Up's and Controls with Cooler, for Track Days
Two Person intercom installed
Vintage Air
3 Section FIre Systems
Modified Sparco Steering Wheel w/ Control Panel Added
Extra Wide Rear View Mirror
Wiring: "Isis"
Wheels/Tires: (One Set will be for Wet/Dry, the other for Dry Only)
Front: 17X10 PS Engineering, "T/A II", aka "Mini-Lites", with 285 mm or Larger Depending on Fender Modification.
Rear: 17X12 PS Engineering, "T/A II", aka "Mini-Lites", with 315-335 Tire Brand TBA
Front: 17X10 Kenesis 3-Piece Wheels 285mm
Rear 17X11 Kenesis 3-Piece Wheels 315mm
There are many things I'm sure I have forgotten. As things start to come together, I would enjoy answering (Or at least Trying to Answer) any questions you might have. It will take a while, but we are getting things pretty planned out. Most things are sourced, the logistics are coming together, however there are still plenty of hurtles.
Jake Parrott, Ben Hermance, and myself have been working on this project already for a number of months. Due to the many Design elements it has taken a while to get them resolved. Ben has been a huge help cyphering my unintentional cryptic directions and notes.
I feel confident that Jake will do a terrific job on this project, and help make these ideas into something Beautiful. We should have plenty of pictures.
I truly welcome ANY and ALL Comments on this Build. Both Pro and Con, along with your reasons. I am very interested in your thoughts.
Take care and thanks for reading.
Sincerely,
Ty O'Neal
Bryce
05-05-2010, 05:27 AM
WOW, this is going to be awesome. i like all the aero mods!. Are you planning on running any CFD analysis? Wind tunnel tunning?
Why not an entire chassis?
cant wait to see this finished!
joemac
05-05-2010, 05:43 AM
I must say the rendering came out good, a little different taste to all the '69s out there.
Bryce
05-05-2010, 05:52 AM
the side profile in the sketch almost looks like a 69 mustang. I like it!
19,69camaro
05-05-2010, 06:10 AM
Nice concept and I really like the rendering but as far as aero stuff goes I would work about that gaping hole in the front grill first
1994 Python
05-05-2010, 06:21 AM
I really like the concept. Can't wait to see some pics of the body mods. I'll enjoy seeing something a little different.
Bjkadron
05-05-2010, 06:35 AM
First off.. Nice project! It looks like it is going to be sweet! As far as the aerodynamics go I have 3 suggestions
1. If you louver the bellypan under the engine compartment with a slight "bump" in front of it you could have a low pressure zone that would not only help downforce but actually suck the hot air out of the engine compartment.
2. Canards are "draggy" so unless you are going for ultimate downforce you might consider not using them. you can get more than enough front downforce to counteract your spoiler and rear diffuser using just the splitter with the ends. On the other hand they do look really cool... So it just depends on your goals.
3. Have you considered blocking off the grill area so that no air gets through? you could get a lot of drag improvement and ust use your lower inlet for the cooling air. It would be higher pressure too because of the splitter. You could also duct the radiator directly to the large vent in the hood for the ultimate in airflow.
Also why did you decide to use Penskes in the front and Spax in the back?
Fast68back
05-05-2010, 06:47 AM
I was thinking it looked more like a Torino
GrabberGT
05-05-2010, 06:55 AM
From the windshield back its an AMX to me. LOL
93Polo
05-05-2010, 08:02 AM
I was thinking the same thing on the roof line in the rendering
Like the hood, not sure about the 70 roof, my 1st vision reading the topic was 70 Cuda top, 69 Camaro lower, we'll see once its made.
I do admire the project and the work it will take. Build something you like and drive the crap out of it.
WS6
05-05-2010, 10:29 AM
I think it'll look awesome! Good luck getting this pulled off. Keep us updated with pictures pleeeeeeeease.
tyoneal
05-05-2010, 01:18 PM
Thanks for all the feedback. I will see if I can answer some of the questions asked.
There will be some Aerodynamic Tuning Done, however wind tunnel time in the classic sense is REALLY expensive. I intend to post what we are doing when we start that process. I'm still trying to my arms around a few other things that will be happening first.
"gaping hole in the front grill"
Part of the Premise:
1. Needs to not lose the '69 Camaro Look
2. Needs to "Enhance" the overall performance/performance possibility of the car in some way.
3. Needs to be something that isn't a completely "Different" car
4. I wanted to try to stay within the confines of a time in "Camaro History"
The Grill of the 1969 Camaro is one of the most Iconic designs of any car from that Era.
The car will need to remove heat from the engine compartment in a big way. Closing of the, "opening" you speak of would/should cause overheating. The car must be required to run hard.
Update:
The Idea you speak of is sound. I've messed with other cars using this idea on several different areas. Yes it does help extract the heat! "Gurney Flaps" seem to work well, and can be used in a number of places. This is something I will implement in future cars. Thanks for the suggestions.
Is that what you are referring to?
UPDATE:
There are a number of tuning devices that seem to help to a certain extent. Since most of the drive will be at less than 100 mph, my first thought is to focus on a lot of balanced downforce. I do REALLY want to see if I can gain some measurable advantage by using these different ideas. Some might work pretty good, others might have have almost no effect for one reason or another. I don't want to artificially clutter the car, I just want items that truly add something to the performance of the car. There is certain to be a lot of trial and error. For me this is part of the joy of the project.
c. I am hoping a Functionally Fast car will be a Really Cool Car
3. Have you considered blocking off the grill area so that no air gets through? you could get a lot of drag improvement and just use your lower inlet for the cooling air. It would be higher pressure too because of the splitter. You could also duct the radiator directly to the large vent in the hood for the ultimate in airflow.
UPDATE:
I am open to trying many different things to accomplish the goal of efficiency. Since I first started this project there have been a number of really great cars built. I hope I can refine the scope of the project, while I'm working on the Grand Sport.
4. Why did you decide to use Penskes in the front and Spax in the back?
Mark Mager, who owned the car before me, recommended these to me. He was the Designer, and Owner of Lateral Dynamics. I figured this would be a good place to start since he had more insight than anyone with his product.
I hope these answers are helpful. If I have missed the point of your question, or anything else, just ask and I'll take another stab at it. Most everything on the car is being done for a reason.
I appreciate your interest and encourage in this build, and I hope you will enjoy seeing it go through this process.
Ty O'Neal
Conrad283
05-05-2010, 01:40 PM
Subscribed ... This should be an awesome build ...
When do you plan to start building?
ncardanini
05-05-2010, 01:42 PM
That camaro is bad. I saw one of the Baldwin-Motion camaros and they weren't going to use the rear seats so they moved the engine, tranny, dash, firewall and seats back. Are you guys going to lower the engine or move it back at all? Also are you using a dry sump lubrication system on the ls3?
sebtarta
05-05-2010, 01:55 PM
OMFG that rendering is SICK!
has this kicked into 1st gear yet? any progress pictures?
hookemdevils22
05-05-2010, 02:04 PM
= LS7? (LS7 being 427 cubes, with heads eerily similar to the LS3)
hdesign
05-05-2010, 05:51 PM
Thanks for the opportunity to help you on this Ty. This has been a long term project with a lot of thought and I'm proud to be a small part of it.
As for the roof.....AMX, AMX, AMX all the way....LOL It's one of those things I struggled to even suggest it to Ty. I know I'm not the only one that believes that a 69 Camaro has one of the most gorgeous profiles a muscle car could have. Screwing with that was a tightrope walk for sure. However, there were some functional benefits to it regarding aerodynamics. It wasn't like we were trying to do something different for different sake or just arbitrarily modify it.
I really can't wait until this car get's completed. The great thing is that Jake's shop is only a few hours away in Maine. I can go bug the hell out of him for a sneak peak....right Jake?
Bjkadron
05-05-2010, 07:20 PM
I am still "in the Books", trying to create a usable "Venturi" for that reason among others.Is that what you are referring to?
Yes.. but any pressure difference would work.. Have you considered something like vortex generators? Or just a small lip should do it...
This item was "discussed" at length. They are on the car for a couple of reasons:
a. They can bring some additional "Tuning" to the car, in several different variations.
b. They can be a useable addition within certain applications, but since I really want the car to be able to perform, first and foremost, in a long fast format they would probably not be used at all, or at least for downforce.
That sounds good. and if they are removable that is even better. Just remember that if they are directly over your splitter it will negatively affect both.
That to, was looked at, but somewhere the car will require x amount of cooling. If the ability is not designed in upfront, then going back and re-designing has to take place. The time and the dollars to do that were not part of the budget, so I wanted to try and get it right or at least close upfront on the first try.
The reason I suggested it is because you have the lower front vent already there. and from the drawings it is at least the size of the stock one. It is also much higher pressure due to the splitter. If you lower the radiator you could duct it directly to the opening then to the outlet on the other side. But how easy that is to do depends on the design on the core support. As for X amount of cooling this would be MORE efficient than the stock setup.
I See.. Do you happen to know how I could get in contact with him?
I have some questions about some of his products that are out of production. You can PM the info to me if you don't want it public.
Ty O'Neal
tyoneal
05-07-2010, 02:28 PM
Hi Guys!
Sorry I've been absent, I had to put my wife in the Hospital as she has pneumonia. She will be fine, I've just been hanging out with her at the Hospital the last couple of days and being supportive.
I'll catch up real soon.
Ty
MarkM66
05-07-2010, 03:39 PM
Where are you at in the build process?
Bjkadron
05-07-2010, 04:34 PM
Hi Guys!
Ty
That is no good! We will keep her in our prayers and hope she recovers quickly!
tyoneal
05-19-2010, 04:37 AM
Hello Everyone:
Sorry it has been so long since I last posted.
My wife is fine now thanks God. Life is starting to resemble normal again.
Will start answering questions and updates again.
Thanks for your patience.
Ty O'Neal
"She Devil"
tyoneal
05-19-2010, 04:43 AM
The Car is underway now. I'm getting some pictures ready to post. I'm working on interior designs, and sourcing some of the parts I need.
Jake has already started on the front subframe. I hope to get some pictures for that as well. He will take the car in the next 3 weeks or so to Maine. There a lot of the sheet metal work will be done, and the new engine will be installed.
I'm still catching up myself. I hope this helps.
Ty O'Neal
"She Devil"
tyoneal
05-19-2010, 05:11 AM
Hi:
Regarding your questions. We will try to lower the engine as much as possible, but we want to avoid a lot of the issues that come with extensive lowering, moving the engine back etc. Since there is going to be a ton of aero-styling done to the car already, I didn't want it to turn it into a tube frame race car instead of a "Pro-touring" Car.
It gets very tempting to just build a race car with Camaro Body parts fastened onto it. I really want to keep my Camaro a Camaro so when going to the events and running against the other "Pro-Touring" cars, I can compete with them rather than having something so different that it would give me an unfair advantage.
The old cars with new technology is what I like about the Pro-Touring hobby. Trying everything you can think of to improve the performance is a blast. I don't want to lose that.
These are old cars with older technology. These inefficiencies are what makes them fun. Too much change Makes the challenge go away. Yes it will still be a block going down the road. I've just tried to smooth out a few areas to help it along.
I know there is a fine lines between some of these Cars vs. Technically a race car. In this build I want to stay on this (Pro-Touring) side of that line.
It would probably get beaten by the, "RaceCars", but I think with a lot of driving lessons on my part, Bettie aka. "She Devil" would at least hold it's own with the other, "Pro-Touring" cars.
Does this make sense?
Thanks again,
Ty O'Neal
"She Devil"
tyoneal
05-19-2010, 05:19 AM
It is a Stroked LS3 out to 427 Cubes. Mast also offers a 416, but I wanted to keep the 427 Size because that is what was run in these Great Cars in the Past.
You might say it's an Homage to the past.
Hope this helps.
Take Care,
Ty O'Neal
"She Devil"
tyoneal
05-19-2010, 07:39 AM
[QUOTE=Bjkadron;668827]Thanks for all the feedback. I will see if I can answer some of the questions asked.
Yes, actually I have. Your right about the pressure working. I just want to see if I can make it as efficient as possible. I'm sure I will have to try different things, but that's part of the "Hardship" we take on.:) Like Penny, Bettie will also need a face lift from time to time.
I do intend for them to be removable. For instance I live in Texas and we have the Texas Mile. That would be a venue where I would remove everything that I felt would slow it down and hurt the performance. True Pro-Touring performance is what I am after first and foremost. I want this car to perform at an excellent level for what it is intended to be, by comparing it to other Pro-Touring builds. I'm sure cars that are technically "Race Cars" will probably have an advantage on me, however, Bettie and I will give 'em hell every chance we get.:1st:
I understand what your saying. When I get together with Jake, we will certainly look at doing what we can to make everything fit correctly and efficiently . The cooling is one area I am absolutely anal about. Where I live (Dallas) it can easily get over a 100 degrees and stay there for months. I do plan on driving this car a lot. Since traffic is a way of life, sitting in 108 degree weather WITH the A/C on and not getting hot, can be a real challenge on any cooling system. I have a MARK VIII Cooling fan that I will be putting in the car. From past experience they are hard to beat if everything is ducted correctly. It's easy to keep a car cool if you have the benefit of lot of air going through the radiator while driving down the highway at 70 MPH. The situation mentioned earlier of sitting still in traffic, and keeping things cool when thrashing hard around the track are what the real focus is. At least at the track the A/C will be turned off. I already have a "Cool Shirt" system that will have a dedicated place to be with the power needed to run it. I hate being hot and it looks like a great invention for people like me.
I hope this will help, a Company called, "Speed Tech" was handling the Lateral Dynamics 3-Link at one time. They are great people and produce a real nice system even if they don't have the 3-link anymore. Here is their web address:
http://www.speedtech-performance.com/
Give them a shout and see if they can hook you up with a Lateral Dynamics Product. As far as getting a hold of Mark, I haven't visited with him in quite some time. The folk at Speed Tech can at least point you in the right direction and maybe even have his phone number. I will check also and see if I have it in some old post. His 3-link is a very nice product.
[COLOR=Red]I hope these answers are helpful. If I have missed the point of your question, or anything else, just ask and I'll take another stab at it. Most everything on the car is being done for a reason.
Ty O'Neal
"She Devil"
tyoneal
05-28-2010, 01:32 AM
To Everyone:
Sorry for the delay, my wife has had a relapse and I had to put her back in the Hospital for severe Dehydration. They Gave her tons of Fluids, 2 units of Blood, Oxygen, and now some PT, as She has become weak through this experience.
I am terribly concerned with her health, and until she recovers, I will only be able to post every now and then. If this is too much information, I apologize.
If you wouldn't mind, please continue to keep her in your thoughts and Prayers.
With God's help and great Doctors she'll be home soon.
Ty O'Neal
tyoneal
08-07-2011, 02:00 AM
I have posted some of these pictures on other sights, but not here. This will at least help show you where everything is with the car. I wish this was moving faster, but I have pretty much finish another project I was working on, and am really able to "Make Tracks" on the Corvette Grand Sport. So REAL progress on this will continue to me slow for a while longer. I'll set up a Thread for the other projects, I hope you like them.
In the mean time, the following pictures will show you the current state of the Camaro. I have had installed a really nice cage, the "Mini-Lite" wheels from PS Engineering, There are a few pictures of the Mast Motorsport LS3 427 SS that I bought for this car. (It might wind up in the Grand Sport before it's all over, however I will put a decent power plant in this as well)
http://psvintagewheels.com/
http://www.mastmotorsports.com/2010/
Finally, there are some decent pictures of the "JRS" Sub-frame that should be arriving shortly. I hope you can get an idea of how it is designed. It uses C6 Technology, and has some pretty nice performance specs.
http://www.jakesrodshop.com/Home.html
Anyway enjoy these few pictures, and check out the other projects if you have the chance.
Take care,
Ty
craigs73
08-07-2011, 07:50 AM
when you gonna start all the body mods?
tyoneal
08-08-2011, 01:53 AM
Craig:
I will return to this car as soon as I finish the Grand Sport Corvette I'm currently working on. I had been waiting for some very needed parts, then we went through a spell of health issues, and in the meantime, I was able to acquire a 64 Corvette Project that needed finishing. The price was right and it pushed itself to the front of the line.
I have the C4 chassis for it now and just about all the parts necessary to finish it.
I am very much looking forward to the Camaro project. It will take some time to get everything right on it, and there are a couple items that will require some special engineering. (But that is the fun part right?)
As soon as I get rolling on it even if it is in a small way, I'll start posting on this board. Keep an eye out, and I will get going on it before to long.
Sorry it has taken so long. Since I announced the "She Devil" Project, I have all but finished a great 1965 Riviera with some retro Pro-Touring Treatment to it. I'll get it posted as well, you might like it. It has a Different look at Pro-Touring in a more classic style.
Also, I picked up a nice 1962 TR3B for my Patient wife who encourages these projects. It is also almost finished, with just a bit of interior work needed to complete it. It's not Pro-Touring in anyway, but its just a very nice English Classic.
Thanks for the continued effort following this, it is appreciated.
Ty O'Neal
craigs73
08-08-2011, 06:21 AM
hey ty post up the vette in project section :)
tyoneal
09-12-2011, 01:38 AM
Done.
Ty
