    Results 1 to 16 of 16
    Thread: g-body wheels?
      Mar 2010
      g-body wheels?
      Hey guys, just wondering what size wheel/tire with the right backspacing i can go without notching in the frame rails. Would like to have the biggest tire i can get under the car. Post up your wheel/tire combo!
      Pics would also be great, would let me see how they would look under the car.
      Thanks guys!
      Washington, MO
      All g-bodies arent the same... what are you working with?
      Mar 2010
      81 malibu stock 7.5 rear end not narrowed.
      Eastern Virginia
      I have 17X8-4.5" backspacing (I think, maybe 4) front & 17X9.5 with 5" backspacing rear. 7/16" spacer on rears.
      Scot
      86 Monte SS
      South Ga..
      I have a 81 malibu but want the opposite..I want staggered setup bad lol love the deep dishes
      tx
      79 malibu
      this is 17x9.5 on all four,285/40 in back, 275/40 in front,back is 1/4" negative offset.
      66 Impala
      86 Corvette
      85 C20
      77 Cordoba
      Since the thread is open, how about an 86 el Camino?
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      tx
      elco...
      this is 1/4" negative 8"wide 275/60-15
      66 Impala
      86 Corvette
      85 C20
      77 Cordoba
      Jul 2007
      Beyond
      Country Flag: Ireland
      Quote Originally Posted by skybu View Post
      I see you mentioned rear is -1/4" offset, but you did not note for the front. Is it 0?
      -Michael 1987 Cutlass
      tx
      front offset with 9.5" wheels and 275/40-17 tires
      In the picture I was using 1.25 inch spacers on the front.
      that would make the offset on the front, at the time, +12mm or 1/2".
      @+12mm the wheels hit the upper control arms on the inside just a tad at full lock on the steering wheel.
      I never tried it but +6mm or 1/4" offset on front, I think, would be perfect.
      @ 0 offset I think they might rub on the outside.
      66 Impala
      86 Corvette
      85 C20
      77 Cordoba
      May 2008
      South Jersey
      Play around with this for a bit http://www.rimsntires.com/rt_specs.jsp
      Nick
      '67 Chevelle 350/th350..... soon to be all aluminum 5.3
      '73 Chevelle 4.8/th350
      Jan 2007
      Central Pennsylvania
      I have 17x9.5 wheels with 4 3/4 inches of back spacing with 275/40 tires on a stock 1978 malibu lowered 2 inches. This combo JUST fits my car that has had no fender trimming or frame cutting. I will say 4.75 backspacing is the maximum for a stock G-body!
      Current rides.
      '09 Challenger SRT
      '05 Ram SRT-10
      '03 Cummins Ram quad cab
      Current Projects
      '71 Challenger Resto Mod.
      '78 pro touring G body malibu.
      Jul 2007
      Beyond
      Thanks fellas. I've been humming and hawing at installing some Camaro wheels I picked up from GMPP for cheap a while ago.
      Just need to figure the correct spacer for my '87 Cutlass.
      San Antonio, TX
      Quote Originally Posted by Samckitt View Post
      I have 17X8-4.5" backspacing front & 17X9.5 with 5" backspacing rear. 7/16" spacer on rears.
      I have the same size wheel and offset. I run 5/16" spacers since that is what was available.
      You can run 245/45/17 and 275/40/17 on that setup on the Monte.
      A 4.75" backspace on the rear, if available, would be better.
      The 4.5" bs on the front, lines-up the tire into a deeper area of the inner fenderwell on the Monte.
      Eastern Virginia
      Mike,
      Here is a Monte SS with those Camaro wheels.
      http://www.dumpit.org/grimreaper/tires-n-wheels.htm
      It's not mine, just thought I would send you the info.
      Scot
      86 Monte SS
      Woodbine, MD
      love that monte!!!
      Douglas Lutes
      1988 Monte Carlo SS
