Results 1 to 7 of 7
Thread: CS140 wiring
04-28-2010 #1
- Join Date
- Apr 2010
- Location
- Florida
- Posts
- 5
CS140 wiring
I'm installing a taurus elec fan in my 65 GTO and eventually AC someday so I had to upgrade my alternator first. I found a CS140 out of a 95 caddy in the boneyard for $20. btw, there's tons of em probably because of cfc and the reason why they are so cheap.
Went straight to autozone to test it. ,...tested good and had quiet bearings. I rotated the clock wiring orientation to straight up instead of 4 oclock. Cleaned it up, changed pulley, it bolted right up and I got the wiring done. It charges right at 14.5 volts.
I've seen several different ways to wire it though. The way I followed wiring it said, on the old external regulator, to jump the outside wires and snip the "extra" resistor brn/wht wire behind the fuse box because it only likes to see "one" resistor ...the gauge light.
My question is ..... the other ways I've seen to wire it also said to jump the 2 inside wires of the external regulator together. Do I need to do that? What do they feed?
The 2 speed taurus fan was only $20 too. Out of a 94 Lincoln continental. I also already installed this same fan in my s10 and it won't budge over 190 with the AC on, with the fan on low, when it used to climb to 210 at a stop light. My GTO easily climbed to 210 even while driving and I rarely drove it during the summer heat. Now hopefully I can drive it year round without worrying about it overheating.Last edited by Grrr; 04-28-2010 at 11:08 AM. Reason: how do you make paragraphs?
