View Full Version : Project "Ooh $#!+"
tb8125
04-26-2010, 03:33 PM
Its a 1979 Trans Am... I bought it with no motor no trans no seats.. The body was over all in good shape only a couple of rust spots on the fender and pass side floor... Other than that a solid starting point
Plans so Far
1998 LS1 /w 4L60e picked that up a week ago... (using BPR motor mount kit not sure what I going to do for transmissin cross member was thinking of using stock one just moved back)
Sent the harness to LT1 wiring last week (should be done by next week)
For brakes I am doing C5 up front not sure what I am doing for the rear
I order SC&C upper and lower control arms
I have wheels 20x10 rear and 18x8 fronts no tires
I removed the subframe and started cleaning it up and getting it ready for the new parts.....
68firebird
04-26-2010, 05:06 PM
from the pic the body looks to be in great shape, good luck and keep posting up pics as you go!
MoonMan
04-26-2010, 06:19 PM
BRP sells the crossmember too. I got the whole "kit" for my car...it's made for a 4L60E. One note, I did have to notch the frame slightly where the crossmember goes to get the correct pinion angle.
cdoggy81
04-26-2010, 08:07 PM
She does look to be in good shape. It will be a cool ride when done.
For the rear (& depending on your budget) you can go with the stock setup that came on the LS1 camaro & firebirds. BRP sells the adapter plate for $40. If you want bigger you can go with the vette stuff or Wilwood. 1979 was the 1st year for rear disc on firebirds so you could also just get some drilled or slotted stock disc to match the C5 rotors you are going with.
What other mods are you doing (suspension, interior, etc)?
tb8125
04-27-2010, 06:21 AM
For the rear I am going to get Pro Touring F-body spring front and rear... With soild body bushing and subframe connectors...
My goal for the next few weeks is to get everything all cleaned up and back to a clean roller... Then I will start on installing the power train...
Interior still unsure on that want to do a 4 gen set up but want to keep things clean and simple ( trying to stay away from the cheese factor)
avewhtboy
04-27-2010, 09:24 AM
Nice project what color is that?
Motown 454
04-27-2010, 10:25 AM
The car looks good and sounds like a nice project. Good luck with it.
cdoggy81
04-27-2010, 02:43 PM
Pro Touring F-body has some good items & he knows his stuff :)
What about the front end?
tb8125
04-27-2010, 02:48 PM
not sure what color that is but its not staying
tb8125
04-27-2010, 02:51 PM
front is getting sc&c upper and lower control arms
cdoggy81
04-27-2010, 06:21 PM
Mark knows his stuff too. Good choices for both :)
tb8125
04-27-2010, 07:52 PM
Did you get that GTO dash to fit in the car.... I was thinking about doing that with 4th gen stuff
CruizinKev
04-27-2010, 07:56 PM
good luck with the nice project! :twothumbs
cdoggy81
04-28-2010, 07:56 AM
Not yet........
but my friend Aaron has already done it with the 4th gen stuff. It fits really good too:
tb8125
04-28-2010, 10:31 AM
is he using the 4 gen fatory guages too
srh3trinity
04-28-2010, 03:25 PM
That 4th gen dash almost looks made for the car. How much work do you think he has in it to get it to that point?
tb8125
04-28-2010, 07:44 PM
Got my upper control arms in today.... Hopefully this will give me the push to finish up cleaning the subframe
tb8125
05-05-2010, 06:46 PM
This last week I have not made any head way on the car... But I have been ordering parts and planning this build out a little more.... I order a custom works c5 brakes kit I am using ls1 calipers with c5 abutments... I also pulled the trans am dash, and sent the guages out to be wired with the rest of the harness
tb8125
06-30-2010, 05:05 PM
The motor I bought was DOA... But I was able to find a 2000 vette motor with very low miles.... I should be get my harness and ecu back here in a few days.... Over the past few weeks I was able to get the front subframe complete
tb8125
06-30-2010, 05:11 PM
rotors are just for mock up
cdoggy81
06-30-2010, 05:20 PM
Who did you send the gauges out to?
tb8125
07-01-2010, 06:18 AM
http://www.lt1350.com/
68firebird
07-01-2010, 06:33 AM
Lookin good man!!!
tb8125
08-25-2010, 05:06 PM
Update I got the new motor and trans (2000 Vette) installed... the front brakes are complete now front suspension is also done I put the subframe back on the car I used the soild body bushing from II Gen products. I was also able to get motor mostly all wired up... I am working on get the plumbing done for the Fuel, brakes and trans now.... I started stripping the car down to bare metal and doing a few patches here and there
cdoggy81
09-28-2010, 03:37 PM
Nice progress so far!
tb8125
10-22-2010, 07:48 AM
I just got the car all wired up the dash and all.... I started to car lastnight.... This small step has put a new fire under me to get this thing done....
tb8125
02-24-2011, 02:42 PM
its been slow but I had to move to a new better garage.... I have a air compressor and a paint booth next door the body of the car is ready to be sprayed but I still have to get the hood, fenders, doors and front bumper ready for paint I am still chugging along here's a couple of pic
THE TECH
02-24-2011, 02:52 PM
Subscribed!
tb8125
02-24-2011, 02:53 PM
and one more
opnwide
02-25-2011, 03:37 PM
cool to see another T/A on the forum. I like that dash conversion.
tb8125
06-21-2011, 08:54 PM
I have now added a procharger to this project... the procharger and intercooler have both been installed... Just order my 42lb injectors... once i get the injectors in... i am going to paint then end the car out to get tuned
tb8125
07-13-2012, 07:53 AM
almost done
aps63
07-13-2012, 08:24 AM
Cool project, lets see some new pictures.
WS6
07-13-2012, 05:05 PM
Looking good. I'm glad to see you hadn't given up on the car.
tb8125
07-15-2012, 09:53 AM
Yeah I have been working on it as much as I can..... I have a new born so it's hard to get to the shop but I make my way there
keithq69
07-15-2012, 06:09 PM
Add Content
