    Results 1 to 3 of 3
      Rockford, MN
      DSE Wiper kit - what should I use for power?
      The kit comes with what appears to be 10ga wire and a 30a fuse, which is alot bigger than anything I have available under the dash or hood that is switched 12v.
      Does it matter? Seems like overkill not to mention difficult to splice cleanly if I use one of my auxiliary power terminals or jumpers that is only 14ga or so and on a 10 or 20a fuse. Do I need to run a 10ga off the battery and use a relay off my switched 12v?
      1969 Firebird, Black, Parchment Arizen interior, Poncho 383 (4" crank), Kauffman heads, TKO600, Moser 12 bolt, Wilwoods, DSE, Speed Tech, Koni, Hotchkis, GW, 18" TTI's, VA Gen IV, etc.
      Fontana, CA
      Electricity! :)
      For starters, what does the diagram state? Is it a switched or constant power lead?
      Nick R.
      Rockford, MN
      Quote Originally Posted by 6'9"Witha69 View Post
      Sorry I thought I was clear that it was switched. The directions simply state: Connect to 12v switched source.
      So yeah, not real specific. So aside from appearing quite simple, why 10ga and 30a fuse? That's my concern.
