View Full Version : Sub frame bushing question
Fillpot
04-17-2010, 07:52 PM
Guy's was putting some global west sub frame bushings in my 69 camaro and noticed something tonight,the thickness of the male bushings that go at the back of the subframe and the middle not the core support.Two of them are are thicker than the other two far as the male part that slides thru the top of the subframe between the body and subframe,is this suppose to be like this,I put the thicker one in the very back and the thin one by the firewall which just didn't seem right,any ideas.THANKS!
Fillpot
04-17-2010, 08:03 PM
Ok just went to the global west web site and saw that they offer bushings that lower the body 1/2in,i ordered them thru summit and may have got the wrong one's,if this is so has any one used these.THANKS!
04-17-2010, 08:52 PM
I believe the thicker ones go on the firewall points.
vince
Gitter Dun
04-17-2010, 10:08 PM
I'm not really clear on what your saying, but it sounds like you bought Global West 1/2" drop body mounts from Summit but intended to get the standard height mounts. If thats the case, I am using the Global West solid 1/2" drop mounts on my car and will check for you in the morning.
Fillpot
04-18-2010, 03:38 AM
Thanks guy's.
Gitter Dun
04-18-2010, 10:03 AM
The thinner one gets sandwiched between the body and the frame at all points. Good luck!
Fillpot
04-19-2010, 08:15 PM
Thanks for all the help guys but I figured it out,big dummy here ordered the 819 kit or something and was suppose to get the 800 kit,the 819 works with sub frame connectors or something,my mistake.THANKS!
