    Results 1 to 6 of 6
      May 2006
      Rhode Island
      Instrument cluster for 1st gen f-body.....
      Has anyone designed and made our own? I've never done this before but I figured I'd give it a try. My plan is to design something to replace the stock piece so it will hold aftermarket autometer guages, probably make it out of aluminum. I was hoping to grab some ideas off some of you guys that have done this already.
      Rene P.
      Oct 2006
      McKinney, TX
      Covans makes a few, as do some other companies....I'm not a fan--I think the 67-68 Camaro/Firebird dash is one of the most beautiful dashes ever put into a production vehicle...
      I'm assuming your looking for a 68 Firebird.
      http://www.yearone.com/serverfiles/f...ovan&SM=1&SC=8
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Jul 2009
      Chicago,IL
      Route 66 Motorsports has an awesome Billet dash you can put your own gauges in. check it out http://www.rt66parts.com/product_inf...722b904b229caa
      1969 Camaro with 2001 LS1 FAST 92mm Intake and TB, Comp Cam, headers, Circle D Converter, 12 bolt rear with 3:55 (Had to sell)
      #2 1969 Camaro straight 6 starting all over with a LS1 etc....
      Jun 2001
      Newbury Park, CA
      That won't fit a 67-8.
      Sep 2007
      Florida
      Here is a pic of the dash in my 68' made to hold 5 - 2 5/8" autometers.
      Nov 2009
      Prior Lake, MN
      Instrument Cluster
      Yes, I know I didn't make this myself or have it custom made but I love the look on my car.
      http://www.classicinstruments.com/in...mentID=camaro1
      The main complaint would be the tach is not large enough. More useable than you think. The look is stock, too stock with the orange needles and black background. I went with white needles. They also have white faces.
      Multi gauges are the best answer for me instead of making up a panel with 6 different gauges in it.
      Oh, another complaint would be the $1000 check for a gauge cluster. All wired up though and just screw it in. I had a problem with the gas gauge, but it was the float and with some shortening of the tube now works much better.
      "A parent's only as good as their dumbest kid. If one wins a Nobel Prize but the other gets robbed by a hooker, you failed."
