View Full Version : Need input on carb adjustment
Jeff70
04-10-2010, 10:12 AM
Hey guys I sent my eldelbrock q-jet to cliff's for a rebuild. My car is a 71 cutlass with a stock 350.
First what would the factory air/fuel mix screws setting be?
And it was running fine under load when I put it on except at idle it smelled rich and had a rough idle, then I started screwing with the mixture screws now it smells rich idles even worse and throttle response is not as crisp.
Right now I'm set at 4 turns out from the bottom, anybody have a suggestions and where I should be set at? Cliff said this carb is a 1910 and was way to big so he lowered the jetting and set it at 3 turns out.
Jeff
Gitter Dun
04-10-2010, 10:56 AM
I am not familiar with Edelbrock carb,s, but the first thing I would do is check the float level. Once your sure that is correct I would start playing with the air bleed screws and get it to idle decently. Once it was idleing descent I would check the timing. Once the timing is dialed stay with the carb until you have corrected the problem.
Pro Stock
04-15-2010, 01:07 AM
Try this guy, he's the best on Q-Jet style carb that I know of
Dale
<LI class=g>Best vintage carter WCFB restorer ?? - Lateral-g Forums (http://www.google.com/url?sa=t&source=web&ct=res&cd=11&ved=0CCcQFjAK&url=http%3A%2F%2Fwww.lateral-g.net%2Fforums%2Fshowthread.php4%3Ft%3D14291&rct=j&q=%22Val+Headworth%22&ei=a9TGS-zzHYXU8ATg1-noCg&usg=AFQjCNHQzAsJFztUuSag5e6BTNh_uw7CPg)
VAL HEADWORTH comes to mind...........those guys are the nuts for what your looking for.. His phone should be 660 385 5236 ...
www.lateral-g.net/forums/showthread.php4?t=14291 - Cached (http://webcache.googleusercontent.com/search?q=cache:3PAbLEtj27MJ:www.lateral-g.net/forums/showthread.php4%3Ft%3D14291+%22Val+Headworth%22&cd=11&hl=en&ct=clnk&gl=us)
Jeff
John Wright
04-15-2010, 03:45 AM
Keep an eye on the fuel pressure...those needles and seats don't like much above 5.5-6psi and they just won't hold the fuel back while idleing.
Jeff70
04-15-2010, 10:09 PM
Thanks for the reply guys, tomorrow I'm gonna pull it out and play withnit a little more.
Jeff
Vegas69
04-16-2010, 05:45 AM
4 turns will make it pig rich at idle unless your idle feed restrictors are way to small. Start with 2 turns and go from there. You can use a vaccum gauge or rpm to tune for the cleanest idle. The highest vaccum and or rpm nets you the cleanest idle. Then you can fatten it a hair from there to get your drivability.
