Results 1 to 10 of 10
Thread: Mocked up DSE rear suspension
04-28-2005 #1
- Join Date
- Feb 2005
- Posts
- 134
I Set the rear in my 67 camaro today, using the 3 inch drop springs and a moser 12bolt which I had them cut to an axle flange to flange measurement of 54 inches. I am also using the shackle relocation set up and mini tubs with 315 17 35s. I was quite surprised to see how much room I have in the wheel house, the scary part is how close the tire is to the leaf spring. There is maybe 1/16 on the drivers side and a 1/32 clearance on the passenger side. What is acceptable clearance? Is there anything I can do to correct it? Will a wheel spacer of a 1/4 inch do it, and is this enough clearance, are wheel spacers dangerious?
I did take into consideration the thickness of my baer rotors when I came up with the rear measurement. So I dont understand the clearance issue although the leafs were not in the car, maybe thats why. I figured the shackles would move them in a bit more. I would really appreciate your thoughts and suggestions on this and perhaps you could tell me how much clearance yours has.
Thanks Rich
