View Full Version : ? mounting Autometer gauges.
Samckitt
04-04-2010, 07:51 PM
I am trying to figure out how to mount a full set of Autometer gauges in an 80s G body. The problem is they are small & I want mount them in the stock location. I want to go with Autometer, but in the models I like the smallest they make is 2-1/16" to fit in the center 4 spots:
https://static1.pt-content.com/images/pt/2010/04/BYhZJQBGk28KGrHgoHEEjlLlyKFGBKiDoR81fg_1-1.jpg
So for those of you that have mounted these gauges, is the area that is represented by dimension "A" in the below image able to be trimmed so they can be mounted closer together?
So I can do something like this:
Doesn't gain alot, but any bit helps.
dropit69
04-04-2010, 08:42 PM
the trim ring is aluminum so could possibly trim them down...like you have pic of
Jims78elky
04-05-2010, 03:24 AM
You have a PM Scot
-Jim
Samckitt
04-05-2010, 04:55 AM
So is this trim ring what holds it onto the panel, or is there a lip on the can that holds it?
Modo Innovations
04-05-2010, 02:40 PM
There is a lip on the can that sets on the panel and the trim ring is crimped onto the lip. Then on the backside of the Autometer gauge there are 2 threaded posts and a mounting ring that goes over the threaded posts and presses against the panel securing it. I hope that makes since.
Samckitt
04-05-2010, 03:25 PM
Yep it makes sence. So I take it Dim A that is on the Autometer image above is a bezel that doesn't even have to be used.
Modo Innovations
04-05-2010, 05:37 PM
I think the bezel holds the glass in/on the gauge and is also used as trim. I know that on a Stewart Warner gauge ("5) the glass is held in by glue and the bezel covers the glue line and is also used as trim.
canadiantbone
04-05-2010, 07:28 PM
My buddy makes a panel for malibu/monte that replacec the whole facia & you cut out your own holes where you need them PM me for his email address .
Samckitt
04-05-2010, 07:46 PM
I have seen some of the aftermarket ones & to me they don't look quite right, or out of balance.
Example:
