    Results 1 to 8 of 8
      Sep 2008
      Kathleen, GA
      gasoline volume ?
      trying to figure out the capacity of a fuel tank but can only find the measurement for a volume of water (231 c.i per gallon). Now since the S.G. of gasoline is 25% less than water (6.25 vs. 8.33) Would it be safe to assume I can reduce the volume measurement of 231 by 25% and use it for calculations ? Or am I totally off base ?
      Northern Colorado
      Volume and specific gravity (SG) are two independent properties. You can figure out your gallons of volume with the conversion factor of 231 ci per gallon.
      SG is actually the ratio of the density of a substance to a reference substance, usually water for liquids. So the SG of water is 1.00 A source I found shows the SG of vehicle gasoline is 0.739 Since water is about 8.3lbs/gallon (depending on temperature) we have gasoline weighing about 6.13 lbs/gallon.
      Hope this clears things up.
      Adam Moyer
      '69 Cutlass "S"
      Fontana, CA
      Yeah, I was thinking the same thing, volume is volume, whether it be gas, water or whipped cream, the volume is based solely on dimensions of the cotainer.
      Nick R.
      Sep 2008
      Kathleen, GA
      Quote Originally Posted by ammoyer View Post
      duh, that makes sense, thanx !
      Southern Indiana
      a gallon of liquid is still a gallon, SG denotes what its density or weight is, has nothing to do with capacity.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Hildebran, NC
      [QUOTE= whipped cream[/QUOTE]
      The instant I read that, I thought about the old shaving cream commercials where the roller coaster shoots thru the huge pile of shaving cream!!HAHAHAHAHAHAHA!!!
      Randy
      Jun 2009
      Tru dat. 1 gallon of gasoline = same volume as 1 gallon of water. Just different weight due to different density.
      Mmmmmmm....one gallon of whip cream sounds reallly delicious.
      Aug 2011
      LOL...the question how much does a pound of lead weigh? The elusive obvious.
