Results 1 to 7 of 7
Thread: GW-Quote on Cat V system
04-27-2005 #1
"Proper negative camber gain for this particular car requires a taller spindle. The stock spindle is too
short even with dropping the upper control arm pivot 1-inch. Negative camber gain is still not
generated, contrary to popular belief."
Well what the heck does that mean? Are they saying the Goldstrand mod won't give you Negative camber?
04-27-2005 #2If I remember the math right ... The Gmod will not actually produce negative camber under load, it will just decrease (or elminate) positive camber gain under load
By making the spindle taller you are changing the same relationship of angles as by dropping the upper a-arm. Since the a-arm can only drop so far in the mount the taller spindle allows even more angle correction.
BTW the CAT V changes a-arm angle and uses a taller spindle1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
But ask me about my 2004 STi Auto-x car...
Just call me Brett
04-27-2005 #3
