View Full Version : MAF elimination
crustysack
03-20-2010, 03:43 PM
how and why would you eliminate the MAF from an 02 LS1? technical answers appreciated
LSXfan
03-26-2010, 05:53 AM
intake reversion for excessive valve overlap in performance cams
MonzaRacer
03-26-2010, 10:16 PM
Actually I have yet to see a properly set up engine ever require removal of a MAF if PCM is properly tuned to accept the information and use it properly, also note that the system works better if it uses heated O2 sensors in both pipes to maintain proper A/F ratio.
crustysack
03-27-2010, 10:27 AM
thank you gentlemen- I am running an 02 LS1 with a wait4meperformance ecu, no cam modification
