View Full Version : Wheels on 69 TA
ScottT
03-16-2010, 06:32 PM
Why would the wheels that fit on a stock rear ended Camaro with 5.5" BS not fit a 69 TA with stock rear end? Thought they were the same width. From guessing they would need to have 4.5" bs. Would work with 1" spacers. Any clues?
srh3trinity
03-16-2010, 07:05 PM
It may have to do with the lines of the fender/inner fender lip.
ScottT
03-16-2010, 08:46 PM
TA and camaro both stock never been touched body wise
ScottT
03-16-2010, 08:48 PM
Off that theory the TA would have to be set out a whole inch wider on each side. Which the rear quarters are untouched. And the wheels fit how they are supposed to on a camaro. Just need to know if TA rear end is narrower
ProdigyCustoms
03-17-2010, 05:14 AM
Remember Pontiac "Wide Track"? The Firebird has a 1" wider rear. So you need a 6" BS instead of a 5.5. Which BTW, most cast wheels do not come in. if you measure hub to hub on the firebird rear it should be 61 1/2", the Camaro is 60 1/2"
I just had this exact conversation with a Firebird owner and the wheel dealer screwed up and assumed a Camaro fitment would work.
