View Full Version : Autocad anyone?
Mathius
03-12-2010, 08:50 PM
Shot in the dark here, but we have some bright people on this board. If anyone uses Autocad, I have a question.. I'm using 2009. I'm taking a beginning autocad class and I've learned enough that we're starting to dimension whole floors of buildings. Everything I know so far is in 2D though...
I need to layout a cyclone for a friend, and he gave me all the dimensions and I need to put it into an autocad drawing (Dwg). The bottom cone part is what he needs, and I have no problem laying it out in autocad, except that the dimensions call for an angle of 71.70 degrees.
For some reason when I use the line command and enter @45<71.70 it draws the line, but when I go to dimension it, it reads 72 degrees.
He wants exact tolerances on the drawing. He plans to take it somewhere and have them plot it. Does anyone know how I can change that? I went under the units menu and changed the angle dimensions to 0.0000 tolerance, but it doesn't seem to make a difference, even if I change it to degrees/minutes/seconds.
I'm not sure if the problem is in the actual line's tolerance or if the problem is in the tolerances used for dimensioning, or where to fix it?
I normally use the distance inquiry command to double check my line lengths, but I don't know how to do that to check the degrees of an angle.
Anyone that can field this one?
Mathius
nvmyss
03-12-2010, 09:31 PM
It's been 10 years since I was a pro at this but, I'll give it a stab.
You need to change the basic setting for the drawing not the dimension tolerance, it seams as if it is set to round up.
I wish I could give you more but I have not even played with it in about 3 years.
Good luck.
smhigh
03-12-2010, 09:47 PM
I'd go into dimension style manager and check the angle tolerances.
These examples may help a little....
http://www.we-r-here.com/cad/tutorials/level_4/4-11.htm
http://www.jlab.org/accel/eecad/acad/advanced_dimen.pdf
Mathius
03-12-2010, 10:08 PM
That did it. Thanks. Apparently it was just the dimensions and the actual line arc must have been ok. Drawing done. Thanks.
Mathius
