    Results 1 to 6 of 6
    Thread: Glowing fuses
      Jan 2010
      Glowing fuses
      help i have a 1968 firebird rear taillights blow fuse when turned on brake lights work fine and headlights work fuse does not blow right away starts to glow seems to have a good ground any suggestions?
      Rustburg, Virginia
      start taking bulbs out until the large amp draw goes away.....take it one circuit at a time and find the culprit.
      Jan 2010
      Thanks will give that a try could be the new headlights
      Sunny Florida on the Suncoast
      Headlight fuse???? GM doesn't have a headlight fuse. Does your Bird have one of the wiring kits like Painless?
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
      USA
      Fuses usually do not glow.
      Glowing would indicate a lot of heat , which would melt (blow) the fuse.
      It sounds like the wire to the taillights is grounding prematurely ( shorting the circuit) somewhere ..
      Or , the ground for the tailights is bad and its backfeeding through another circuit ...
      Is it factory wiring or a Painless kit ???
      Jeff Tate
      U.S.A.
      Jun 2006
      NW burbs IL
      Check your license plate light housing, the wire goes through a grommet that I have seen split and cause intermittent shorts.
      Matt
