View Full Version : FirstGenZq8: test
FirstGenZq8
02-21-2010, 08:58 PM
engine
LT1 355 c.i. (http://parksengineservice.com/)
mahle pistons/rings 11.5:1 (http://store.summitracing.com/partdetail.asp?part=MLE%2DSBC550030F05&autoview=sku)
5.7HP rods w/ bushings
king rod/main bearings (http://www.kingbearings.com/index.html)
cam bearings (http://store.summitracing.com/partdetail.asp?part=DUR%2DCHP%2D8T&autoview=sku)
M155 oil pump (http://store.summitracing.com/partdetail.asp?autofilter=1&part=MEL%2DM155&N=700+115&autoview=sku)
LT1-LE1 head/cam package: stock valves w/ back out, 195 CC intake port, (http://www.eportworks.com/LT1LE1.htm)
CRN-10308-1 valve springs/retainers/locks (http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRN%2D10308%2D1&N=700+0&autoview=sku)
GM lifters 12499225 (http://www.sdparts.com/product/12499225/LifterKitGenIIIEnginesSetof16.aspx)
COMP pushrods CCA-7808-16 (http://store.summitracing.com/partdetail.asp?part=CCA%2D7808%2D16&autoview=sku)
COMP Cams Magnum 1.6 rockers CCA-1305-16 (7/16 stud) (http://store.summitracing.com/partdetail.asp?part=CCA%2D1305%2D16&N=700+4294908216+115&autoview=sku) use w/ ARP-134-7103 (7-16” studs) (http://store.summitracing.com/partdetail.asp?autofilter=1&part=ARP%2D134%2D7103&N=700+0&autoview=sku)
trick flow TFS-30400623-8 guide plates (http://store.summitracing.com/partdetail.asp?part=TFS%2D30400623%2D8&autoview=sku)
sealed power gasket set (http://store.summitracing.com/partdetail.asp?part=SLP%2D260%2D1650&autoview=sku)
ARP Cylinder Head Stud Kits ARP-134-4001 (http://store.summitracing.com/egnsearch.asp?Ntt=arp+134-4001&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115)
ARP Main Stud Kits ARP-234-5601 (w/ windage tray) (http://store.summitracing.com/partdetail.asp?part=ARP%2D234%2D5601&N=700+115&autoview=sku)
ARP connecting rod bolt kit ARP-134-6005 (http://store.summitracing.com/egnsearch.asp?Ntt=arp+134-6005&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115)
Avon Automotive Progear Timing Chain #4145 (http://www.progearweb.com/4000/4145.htm)
polyurathane motor mounts (http://s-seriesforum.com/gallery/album276)
ASP underdrive pulley ASP945103 (http://www.aspracing.com/gm.htm#camaro)
cooling
Summit Direct Fit Aluminum Radiators SUM-380473 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D380473&N=700+0&autoview=sku)
flexalite 210 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=FLX%2D210&N=115&autoview=sku)
JTR cooling tee (http://www.jagsthatrun.com/Pages/Parts_TPI-TBI_Brass-Tees.html)
AC delete (http://s-seriesforum.com/albums/album235/7f_1_b.jpg)
CSR electric WP (http://store.summitracing.com/partdetail.asp?autofilter=1&part=CSI%2D901LT1&N=700+0&autoview=sku)
intake
tfs-3150800 trick flow air inlet elbow (http://store.summitracing.com/partdetail.asp?autofilter=1&part=TFS%2D3150800&N=700+0&autoview=sku)
gp-sorensen TB gasket pack 96-3008 (http://www.autozone.com/R,3759457/initialAction,partProductDetail/store,1368/partType,00522/shopping/partProductDetail.htm)
exhaust
LHT longtube headers
percy's header gasket PHP-66031 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=PHP%2D66031&N=700+0&autoview=sku)
!cats (http://s-seriesforum.com/gallery/album142)
3” dual exhaust
x-pipe
magnaflow 14419 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=MPE%2D14419&N=700+115&autoview=sku)
electrical
vented optispark swap (http://para.noid.org/~muttvette/opti.html)
MSD 8.5mm wires (http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D32149&N=700+115&autoview=sku)
fuel
30# injectors (http://store.summitracing.com/partdetail.asp?autofilter=1&part=FMS%2DM%2D9593%2DB302&N=700+0&autoview=sku)
aeromotive FPR (http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI%2D13107&N=700+115&autoview=sku)
chassis/suspension/brakes
2" spindles (http://www.belltechcorp.com/)
hotchkis springs (http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&Ntt=1902F&searchinresults=false&N=115)
PST swaybars (http://www.p-s-t.com/truck/tvsway.html#CHEVROLET)
prothane total kit (http://www.jcwhitney.com/autoparts/ItemBrowse/c-10614/s-10101/p-100000222574/mediaCode-ZX/appId-10374610/Pr-p_CATENTRY_ID:10000022257410374610)
GTA steering box (http://s-seriesforum.com/albums/album39/aas.jpg)
zq8 frame brace (http://s-seriesforum.com/gallery/album148)
Z06 13” front brakes (http://www.s-seriesforum.com/forum/showthread.php?t=74977)
LS1 rear brakes
LS1 rear brake pads (http://www.autozone.com/N,14401234//shopping/partTypeResultSet.htm)
renzfab ebrake brackets
SS F/R brake lines (http://www.precisionbrakescompany.com/brake-hoses.html)
ground force 3 in mono leaf # 2010 (http://www.performancecenter.com/partnumber/GDF2010)
steering shaft (http://www.syty.net/forums/member.php?userid=2655)
boosted bars (http://www.s-seriesforum.com/forum/showthread.php?t=82478&highlight=summit)
lowering blocks (https://shell7.tdl.com/~jags/Pages/Parts_S10-Lowering-Blocks.html)
axle set back plates (https://shell7.tdl.com/~jags/Pages/Parts_S10-301.html)
howe tall upper/lower ball joints (http://www.scandc.com/balljoints.htm)
tubular LCAs (http://www.umiperformance.com/3031)
tubular UCAs (http://www.speedwaymotors.com/p/4853,26_4130-Chrome-Moly-Metric-Upper-Control-Arms.html?itemNo=a%20arms)
front coilovers (http://autofabcart.net/)
wheels/tires
ZR1 wheels w/ 315/35/ZR17 & 255/40/ZR17 KDW's (www.)
skulte 2” adapters for rear wheels (http://www.skulte.com/)
315/35/17 tire height=25.68"
255/40/17 tire height=25.03"
T56
first gen 5 speed pedal assembly
CNS-SC126869 coni-seal clutch slave cylinder (http://store.summitracing.com/partdetail.asp?autofilter=1&part=CNS%2DSC126869&N=700+0&autoview=sku)
CNS-CM126857 coni-seal clutch master cylinder (http://store.summitracing.com/partdetail.asp?autofilter=1&part=CNS%2DCM126857&N=700+0&autoview=sku)
BYUNSPEED short shifter handle (http://www.byunspeed.com/product_info.php?cPath=2902_359_1588&products_id=6796&osCsid=96b27b85b815766dd59e0d6e09dc33f1)
ctf-df039020 centerforce dual friction clutch (http://store.summitracing.com/partdetail.asp?autofilter=1&part=CTF%2DDF039020&N=700+0&autoview=sku)
a7721 corvette lower shifter boot (http://www.ecklers.com/product.asp?pf%5Fid=A7721&dept%5Fid=1643)
51799 corvette upper shifter boot (http://www.ecklers.com/product.asp?pf%5Fid=51799&dept%5Fid=1643)
motormite pilot tool 14523 (http://www.oreillyauto.com/)
motorite pilot bearing 14650 (http://www.oreillyauto.com/)
engine dress up
grille insert (http://www.syty.net/forums/showthread.php?t=42425&page=1&pp=15)
accelerator linkage cover (http://motors.search.ebay.com/_W0QQsassZnoblecoatingii)
Mr. Gasket Master Cylinder Cover MRG-4573 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=MRG%2D4573&N=700+0&autoview=sku)
made for you wire looms MFY-5035611 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=MFY%2D5035611&N=700+0&autoview=sku)
exterior
bravada grille (http://www.s10forum.com/forum/showthread.php?t=186681)
grille: Carriage Works 40053 (http://www.stylintrucks.com/parts.aspx?category%7ccategory_root%7c-25=Exterior&category%7ccat_-25%7c148=Grilles&partfamilyid=828&attribute_value_string%7cColor=Black&canned_results_trigger=
rear
www.tomsdifferentials.com
208-265-8111
2000 8.5
Eaton HD Posi – page 45 in their catalog part #8.5-EP30
richmond 4.10 gears R8.5
billet 3R yoke #8.5-TYBY $120
forged yoke #8.5-TFY $90
summit aluminum diff covers (http://store.summitracing.com/egnsearch.asp?N=700+4294891995+4294791217+115+4294 901322&rsview=sku&Ns=P%5FSRE%5FDisplayPrice%7C0)
jegs aluminum diff cover (http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_14486_-1)
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_14600_-1
FirstGenZq8
02-21-2010, 08:59 PM
LT4 oil filter adapter
PF52 oil filter
brakes/suspension
Brake Bolt Proportioning Mod (http://powerperformancemotorsports.com/product.sc?categoryId=1&productId=1749)
billet tie rod adjuster sleeves (http://www.ridetech.com/catalog/Billet_Tie_Rod_Adjuster_sleeves-2486-1.html)
cooling
Goodyear Replacement Belts and Hoses GTR-5006 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=GTR%2D5006&N=700+115&autoview=sku) $109.95
goodyear high miler notes (http://web.camaross.com/forums/showthread.php?t=490169)
silicone vac hose SYTY (http://www.syty.net/forums/showthread.php?t=64737)
silicone SYTY 2 (http://www.hosetechniques.com/index.html)
optispark options:
optispark harness (http://www.eficonnection.com/eficonnection/default.aspx)
optispark harness (http://www.eficonnection.com/eficonnection/lt1_pigtails.aspx)
PCM recal
PCM recal (http://www.pcmforless.com/)
!Emissions (???)
!EGR (???)
intake
intake hose (http://motors.shop.ebay.com/items/intake-hose_W0QQ_nkwZintakeQ20hose)
silicone tubes (http://www.siliconeintakes.com/)
silicone couplers (http://www.siliconecouplers.com/)
http://store.airflo.com/34p-500.html
LT1 Throttle Body Bypass (http://www.lt1tips.com/)
exhaust
v-bands (http://performancecloseout.com/cart.php?target=product&product_id=306&category_id=101)
HOK-22207HKR , MPE-35190 , MPE-35104 , MPE-35134
HYDROBOOST
1 (http://www.syty.net/forums/showthread.php?t=38220) 2 (http://www.syty.net/forums/showthread.php?t=44181&highlight=hydro) 3 (http://minitruckzone.tenmagazines.com/articles.asp?page=tenarticle&aid=2924) 4 (http://www.s-seriesforum.com/forum/showthread.php?t=81139) 5 (http://www.s-seriesforum.com/forum/showthread.php?t=76443&page=1&pp=40&highlight=hydroboost)
batteries:
Braille batterys (http://www.brailleauto.com/)
optima battery mount (http://www.halbigmachining.com/auto/battmount.html) $99.00
alternative battery mount (http://www.detroitspeed.com/productpages/indproduct/electricalprod/battery_mounts_group_51_prod.htm) $70.00
summit battery relocation kit SUM-G1231-K (http://store.summitracing.com/partdetail.asp?part=SUM-G1231-K) $109.95
FirstGenZq8
02-21-2010, 09:00 PM
underhood
longacre magnetic drain plug (http://www.longacreracing.com/catalog/item.asp?id=541&catid=17)
radiator cover (http://www.jegs.com/p/JEGS/814385/10002/-1/10597)
stainless steel radiator support (http://74.205.64.102/ProductDetail.jsp?LISTID=1090000-1113432641)
LT1/4 starters (http://www.turbobuick.com/forums/junkyard-dogs/23707-lt1-starter.html)
wheels/tires
gorilla wheel spacers (http://store.summitracing.com/partdetail.asp?autofilter=1&part=GOR%2DSP601S&N=700+4294847663+115&autoview=sku) $5.99
wheel spacers MM816449N (http://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=mm816449)
lug nuts:
scratchless sockets (http://www.toolrage.com/prodview.asp?sku=ATD-4355)
scratchless sockets 2 (http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40035)
lug nuts (http://www.evasivemotorsports.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=L1)
lugnuts 2 (http://www.weaksauceparts.com/store/home.php?cat=2168)
lug nuts 3 (http://bloxracing.com/index.php?cPath=52)
chassis/suspension
c notch (http://www.suicidedoors.com/Bolt-inC-NotchKit.php#)
driveshaft loop (http://www.jegs.com/i/Jegster/550/40734/10002/-1)
a-arm spacers (http://www.hrpworld.com/index.cfm?tpc=A-Arm_Spacers&form_prod_id=893,891_4404&action=product)
longacre a-arm spacers (http://www.longacreracing.com/catalog/catlist.asp?catid=5)
interior
shift light (http://www.glowshiftdirect.com/index.asp?PageAction=VIEWPROD&ProdID=139)
grant steering wheel GRT-1471 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=GRT%2D1471&N=700+0&autoview=sku)
horn button (http://www.summitracing.com/parts/GRT-5656/)
interior (http://www.stockinteriors.com/)
custom head unit mount kit (http://maptechenterprises.netfirms.com/store/nfoscomm/catalog/index.php)
ram mount (http://www.syty.net/forums/showthread.php?t=57801)
window motor replacement (http://www.syty.net/forums/showthread.php?t=73966)
window motor replacement 2 (http://www.tyclone.com/windowmotor.htm)
center vent mod: http://www.syty.net/forums/showthread.php?t=57762
iTouch as head unit (https://www.pro-touring.com/forum/showthread.php?t=59371&highlight=ipod+head+unit)
iTouch as head unit 2 (https://www.pro-touring.com/forum/showthread.php?t=65584)
T56
shift knobs
shifter boot (http://www.ecklers.com/product.asp?pf_id=51799&dept_id=1602&cm_mmc=ECKEmail_08-_-NewProd04-_-C4-_-51799)
jegs 2” shift knob (http://www.jegs.com/i/JEGS/555/61525/10002/-1/889883|10521)
skip shift eliminator (http://www.speedinc.com/cont.cfm?cid=C0000085)
exterior
tonneau cover (http://s10dragracer.com/FORSALE.htm)
toolbox YH279318 (http://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=YH279318)
s10 sunroof (http://www.sunroofdoctor.com/popupkits.htm)
spoiler support 1 (http://www.irvansmith.com/scart/longacre-racing-products-spoiler-body-supports-c-163_179.html)
spoiler support 2 (http://store.cdoc.com/detail.asp?id=14665&str=2000-0284&name=Shift+Knobs)
spoiler & hood supports (http://www.hrpworld.com/index.cfm?tpc=Body_Supports_and_Brackets&form_cat_id=459&action=category)
dzus fasteners (http://www.jerrybickel.com/dzus-and-rivet-hardware/dzus-fasteners-1.html)
bedliner (http://www.alsliner.com/)
LeBra Low-Profile Tonneau Cover Systems 93-90103-01 (http://store.summitracing.com/partdetail.asp?autofilter=1&part=WLF%2D93%2D90103%2D01&N=700+4294917516+4294908216+4294907469+4294905933+ 4294924928+4294905283+115&autoview=sku)
door seals (http://www.parts.com/oemcatalog/index.cfm?action=getJointLocator&siteid=2&chapter=&Sectionids=0,2399&groupid=3760&subgroupid=2284&componentid=2356&makeid=11&model=S-10&year=1991&graphicID=GD91075&callout=5&catalogid=2&displayCatalogid=0)
spoilers
plastic sheet (http://www.allstarperformance.com/product.htm?prod=155)
aluminum sheet (http://www.allstarperformance.com/product.htm?prod=147)
spoiler support (http://www.allstarperformance.com/product.htm?prod=684)
spoiler hinge (http://www.allstarperformance.com/product.htm?prod=907)
black spoiler (http://www.allstarperformance.com/product.htm?prod=683)
clear spoiler (http://www.allstarperformance.com/product.htm?prod=156)
dress up
intake dress-up (http://www.carolinarodshop.com/Store/htm_files/lt1_parts.htm)
miscellaneous stuff
windshield wiper removal (http://www.centergc.org/images/misc/Mike/gallery/SYCLONE-2932/IMG_0310)
aiming headlights (http://www.s-seriesforum.com/forum/showthread.php?t=73184&highlight=headlight)
http://shbox.com/1/4th_gen_tech1.html
wheel calculator (http://www.rims-n-tires.com/rt_specs.jsp)
BOSS GLOSS (http://www.por15.com/Boss-Gloss?sc=2&category=156)
civic filter (http://www.accessconnect.com/kn_honda_filter.htm)
summit tie wraps (http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-G1860-100&N=700+115&autoview=sku)
hardware organizer (http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-CSUM2007&N=700+115&autoview=sku)
window guide repair (http://www.centergc.org/images/misc/Mike/gallery/Window-guide-repair)
LMC bulk order:
tailgate parts (http://www.lmctruck.com/icatalog/cst/full.aspx?Page=45)
fender arches (http://www.lmctruck.com/icatalog/cst/full.aspx?Page=52)
headliner (http://www.lmctruck.com/icatalog/cst/full.aspx?Page=111)
headlight parts (http://www.lmctruck.com/icatalog/cst/full.aspx?Page=159)
turn signal parts (http://www.lmctruck.com/icatalog/cst/full.aspx?Page=161)
taillight parts (http://www.lmctruck.com/icatalog/cst/full.aspx?Page=165)
miscellaneous mods
mesh: 1 (http://www.twpinc.com/twpinc/control/product/~category_id=TWPCAT_14/~product_id=003X003W0470W48T) 2 (http://www.jcwhitney.com/PRO-PLUS-MESH-GRILLES/GP_2010967_N_111+200730208+600014032_10101.jcw#BVQ AWidgetID)
hammock (http://www.eaglesnestoutfittersinc.com/)
aluminum driveshaft - 99 TA - 4L60E - 41 inches long center of u joint to center of joint.
LT1 nitrous (http://web.camaross.com/forums/showthread.php?t=505133)
RACING
driveway austin (http://www.drivewayaustin.com/main/)
big bend open road race (http://www.bborr.com/)
harris hill roadcourse (http://www.harrishillroad.com/)
FirstGenZq8
02-21-2010, 09:07 PM
Over The Valve Cover wire lengths:
1. 29" _ 2. 30.5" _ 3. 33" _ 4. 33" _ 5. 37" _ 6. 41" _ 7. 41" _ 8. 40.5" _ C. 10.25
As measured BETWEEN the boots.
RUS-648080 -6 AN to 18mm X 1.5 O-ring (http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D648080&N=700+115&autoview=sku) $11.39
RUS-620411 -6 AN 45* powerflex hose end (http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D620411&N=700+115&autoview=sku) $15.95
High pressure Input from Hydroboost Output
RUS-648060 -6 AN to 16mm x 1.5 o-ring (http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D648060&N=700+115&autoview=sku) $7.69
RUS-620421 -6 AN 90* hose end (http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D620421&N=700+115&autoview=sku) $13.95
Pump High pressure output to Hydroboost Input
25" 3/8 Low pressure return line
3/8 Brass "T" for connection
RUS-648050 -6 AN to 11/16-18 in. inverted flare fitting (http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D648050&N=700+115&autoview=sku) $10.95
Hydroboost Input from pwr steering pump
36" SS Braided High pressure Teflon Line
RUS-640380 -6 AN to 5/8-18 in. flare fitting (http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D640380&N=700+115&autoview=sku) $4.95
Hydroboost High pressure Output to steering box input
27" SS Russel Braided High pressure Teflon Line
