    Results 1 to 3 of 3
      Jan 2010
      bad ingnition tumbler?
      well I went out to try and start my 79 trans am but it would not start.
      all the lights worked so not battery .
      I think it has something to do with the key mechanism ?
      if you turn it I get the usuall buzzers but when it is in the on position nothing happens, car can go into gear.
      I tryed for a while to get it to work and it finally cranked until I let off the key but I can't get it to do anything.
      What do you think it could be?
      car started a few weeks ago but won't now car has been in garage since October.
      Marshall , MO
      Neutral Safety switch would be my first guess. If the car is a column shift it will be under the dash on the column. You can remove the plug from it and jumper the purple wires together and see if it will start.
      I don't know where it will be if it is a console shift.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Hackettstown, NJ
      try adjusting neutral safety switch on the column. usually white or blue and 3" long on GM applications. if it is a non chip key (late 80's & earlier), the tumbler simply turns. the only way they go bad is when they dont turn or internally wear out.
