View Full Version : 69 Camaro Project Vert
colin204
02-16-2010, 08:27 PM
My project begins
Tony at Muscle Car Metal did an excellent job restoring the shell.
https://static1.pt-content.com/images/pt/2010/02/DSC_0070-1.jpg
https://static1.pt-content.com/images/pt/2010/02/DSC_0076-1.jpg
https://static1.pt-content.com/images/pt/2010/02/DSC_0072-1.jpg
He also installed the Art Morrison rear subframe during the build that Frank at Prodigy Customs ordered for me. I have a feeling Frank will be getting a lot of my money during this build.
https://static1.pt-content.com/images/pt/2010/02/ArtRear-1.jpg
DSE mini tubs installed
https://static1.pt-content.com/images/pt/2010/02/DSC_0074-2.jpg
Got it on the rotisserie
https://static1.pt-content.com/images/pt/2010/02/DSC_0016-1.jpg
Rod
02-16-2010, 08:35 PM
I like it :seizure: more please
CruizinKev
02-16-2010, 08:57 PM
looks good!! :twothumbs
colin204
02-17-2010, 04:26 PM
Plans for the project:
- 6.2 liter All Aluminum L92 with LS3 intake
- Considering the TCI 6x automatic six speed transmission
- Ricks stainless EFI tank
- Art Morrison front subframe and subframe connectors
- Willwood Brake Package
- Forgeline Wheels
- Smooth firewall and relocated wiper motor
- Custom black interior
- Have not decided on exterior color yet
Motown 454
02-17-2010, 06:12 PM
Nice project keep us updated. Tony does some nice work.
Chevrolaine
02-17-2010, 06:28 PM
Awesome, nice to see a convertible for a change.
colin204
02-18-2010, 07:11 PM
Need some help from the experts. I am going to prep and coat the underside with a bed liner and need to make sure I have the steps correct so it turns out good.
1. Sand any surface rust that may be present on the non edp coated pieces such as the subframe and mini tubs (will 180 grit work?)
2. Red Scotch bright the areas to spray that have the edp coating or should I just use 180 grit?
3. Clean with waterborne wax and grease remover
4. Dry the panels and then wipe down with tack cloth
5. Spray SPI epoxy primer (How many coats?)
6. Seam seal all the panels (any recommendations or favorites for sealer?)
7. Should I put another coat of epoxy primer on and what is my time window from first coat of epoxy primer?
8. Apply bedliner coating (What is my window to put over the epoxy primer without having to scuff with red scotch bright?)
9. What are your recommendations for undercoating? I was looking at Raptor or SPI.
Please give me your input to the above info on what I am using and if I have the steps in the right order.
Colin
colin204
02-20-2010, 07:42 AM
Here are some pictures during the build process:
https://static1.pt-content.com/images/pt/2010/02/100_1785-1.jpg
https://static1.pt-content.com/images/pt/2010/02/MuscleCarMetalBuild6-1.jpg
https://static1.pt-content.com/images/pt/2010/02/MuscleCarMetalBuild7-1.jpg
https://static1.pt-content.com/images/pt/2010/02/MuscleCarMetalBuild9-1.jpg
dropit69
02-20-2010, 08:10 AM
great project i have a dynacorn convert i picked up last year that has 4 link and c4 front clip ill be starting on soon ..i love converts..i will be following your for sure..
dhutton
02-20-2010, 08:30 AM
I'm not so sure that I would put bedliner on all that new metal. I would just epoxy prime it and apply chassis black. I think buyers wonder what is under bedliner when they see it on a car.
I like to use the two part 3M seam sealers.
icemanrd19
11-07-2012, 06:54 PM
when are you going to start the progress pic?
colin204
01-05-2013, 03:38 PM
Starting to make some progress. The car is now at Rod's Car Craft.
Art Morrison front subframe delivered
https://static1.pt-content.com/images/pt/2013/01/47B1D655D1AA46C4909E28DD2E1F0F7361117000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/A4EB11C06D8141A195F6551A8E18094561117000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/8427790247E8478ABF4D64769D3DB4AD61117000-1.jpg
colin204
01-05-2013, 03:45 PM
Smoothing out the firewall
https://static1.pt-content.com/images/pt/2013/01/CF09D1B2FD9148B4B9DB140A2844EAAB61117000-1.jpg
Car on wheels
https://static1.pt-content.com/images/pt/2013/01/8D83C83C4B754BAC985F6F78EB32158361117000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/721727177D5A42DEAE034C2B1E12602361117000-1.jpg
colin204
01-05-2013, 03:46 PM
Subframe connectors being installed
https://static1.pt-content.com/images/pt/2013/01/05848923E47A4933A275DDBD759257D861117000-1.jpg
https://static1.pt-content.com/images/pt/2013/01/AE9290E85EC748ADB2625AD30278D98561117000-1.jpg
colin204
01-20-2013, 08:11 PM
It is now sitting on the ground
https://static1.pt-content.com/images/pt/2013/01/1FEED2CA4BCC4BE3BD386A49752C42B184712000-1.jpg
KnightMare
01-21-2013, 01:58 PM
Great looking build, figured out a color yet?
colin204
01-21-2013, 06:13 PM
I am thinking about Cyber Gray
KnightMare
01-21-2013, 06:33 PM
I was looking at that paint chip the other day for one of my Chevelle's haha
