View Full Version : Looking for this "cowl induction" setup
Mr. Anderson
02-11-2010, 08:02 AM
Anybody know if these are reproduced? Thanks!!
rob07002
02-11-2010, 08:43 AM
This place should have what you're looking for, http://www.ramairbox.com/models.html
chevyhector
02-11-2010, 09:03 AM
What look are you going for? Stock-ish? (if that’s a word) But if you’re looking for a cool 4bbl intake, go to: sprectreperformance.com. I have this set up and it looks very cool and clean.
Mr. Anderson
02-11-2010, 09:23 AM
You are awesome!
That is what I was originally looking for but couldn't find and started considering other options.
Hector - I'd considered that, and like those too. I'm not sold on the looks of the Spectre stuff, and know I don't need anything polished.
chevyhector
02-11-2010, 09:28 AM
I have to say, since that intake install i've had a HP gain. They also mocked up another set up, but not sure if its for sale yet. I'll try to get a pic from them to send you.
rob07002
02-11-2010, 09:39 AM
You are awesome!
Thanks. I've learned so much on this board over the years, it feels good to give a little back.
Mr. Anderson
02-11-2010, 09:42 AM
We did this here at work (from scratch).
https://www.pro-touring.com/forum/attachment.php?attachmentid=36100&stc=1&d=1265910058
My original thought was the dual snorkel kind of setup...then I started considering that my alternator and A/C compressor will be in the way. And if I were to do it, I'd want to keep the regular style sir filter, and route ducts to the inner headlight openings in my grill. Which means cutting holes and making brackets, etc.
I think it will be much easier for me to use this piece from Ram Air Box, and fabricate the rest to meet up with the existing hole in my firewall.
https://static1.pt-content.com/images/pt/2010/02/m8-1.gif
chevyhector
02-11-2010, 09:47 AM
WOW! if you can do this type of work, then I bet you can make your own cowl set-up. great work.
redfire69
02-11-2010, 10:36 AM
Wow! Where was this setup two years ago! LOL! I used the spectre modular setup, but that is way cool. Polishing is no fun BTW!
Ron
chevyhector
02-11-2010, 10:53 AM
Hey Ron,
You can still upgrade your tubes with the custom air box. go on their web site and contact them for a list of the extra parts you need. But you would need to relocate the battery.
Hec
Ron
chevyhector
02-11-2010, 11:44 AM
Ok guys,
Spectre sent me these pics with 2 other set up's, mocked up on my Medusa.
1968Maro
02-11-2010, 12:07 PM
Wow!
I havent seen those setups on thier website.
Custom order?
1969CamaroRS
02-11-2010, 12:08 PM
Going through the radiator support is an interesting idea..
redfire69
02-11-2010, 12:19 PM
I really like those cold air dividers. Sorry for the hijack.
chevyhector
02-11-2010, 12:37 PM
All of these parts are still under R&D, I will let Spectre know that you guys like their designs ! If you’re interested send me a PM and I can give you a contact name.
1968Maro
02-11-2010, 12:50 PM
I got to looking at these setups.
The closeouts for the intakes are designed to work with a pretty specific type of radiator support aren't they.
If it is designed how I think it is, when the hood comes down the gasket at the top of the closeouts will come into contact with the hood and block the hot air from the engine bay from entering the intakes.
But, it seems that 90% of the aftermarket radiator supports want to go right over the same area as that closeout, I am really seeing it in the second setup you showed chevyhector.
Am I looking at that right?
chevyhector
02-11-2010, 12:59 PM
i would like to answer that question David, but I would not have an answer. Spectre would be the guys to ask. How i understand it, is that it is a functional air box and it is separate from the engine compartment air flow. let me ask...
1968Maro
02-11-2010, 01:05 PM
My concern is more will my $260 Billet Radiator supports I just bought work with this setup?
chevyhector
02-11-2010, 01:10 PM
David, I will ask that too?
chevyhector
02-11-2010, 01:45 PM
David, This is what Spectre sent me.
***Hector,
At this time, I think you should let them know that it’s a prototype and you haven’t even seen it in person yet. Suggest that they email
[email protected] (
[email protected]) with any specific questions and we’ll do our best to answer them. As for the aftermarket radiator supports, I am not familiar with them so we’d need pictures to be able to tell if they’d fit or not. ***
OK?
6'9"Witha69
02-11-2010, 01:55 PM
Guys, in technical terms, the "radiator support" is what you bolt the radiator, headlight buckets, and fenders to. The bars are refered to as core supports or fender braces. Perhaps that is causing confusion when trying to get an answer.
1968Maro
02-11-2010, 02:03 PM
Thanks Nick,
You are right
chevyhector
02-11-2010, 02:05 PM
I’m confident that Spectre knows what a radiator supports is, they just need a pic for the dimensions, to check if they will fit the application.
1968Maro
02-11-2010, 02:23 PM
Nick was correcting me, I was the one calling it by the wrong name.
Link to my Fender Braces
http://www.shop.feslerbuilt.com/product.sc?productId=366&categoryId=104
chevyhector
02-11-2010, 02:28 PM
I will send Spectre the pics, lets see what they say.
Charley Lillard
02-11-2010, 10:15 PM
Here is the guy selling what you had pictured.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190355700863&ssPageName=STRK:MEWAX:IT
Mr. Anderson
02-12-2010, 09:08 AM
Whoa.....and I thought the Ram Air Box stuff was expensive! Time to get some fresh sheetmetal and get to work.
BonzoHansen
02-12-2010, 09:39 AM
That is a 67 Z28 part. ~$1000
http://taperfresto.com/cowl_plenum_a_c.html
Charley Lillard
02-12-2010, 05:21 PM
bonzo...I believe the source you mentioned sells a plastic one. The one I mentioned above is steel and aluminum.
BonzoHansen
02-12-2010, 05:34 PM
Snap. Filed under good to know. Cause I want one of those bad. $1100, whew.
Damn, plastic for $950!
Thanks Charley.
Kenova
02-12-2010, 06:07 PM
You and I both. I've been thinking one of those suckers (no pun intended) would look good under the hood of my Nova. It's a little pricey, but if I don't spend it my kids will.
Ken
obengston
02-16-2010, 05:30 PM
Never seems to stops The things I see on here. Its great
Stg1Regal
02-18-2010, 06:23 PM
Originally Posted by Mr. Anderson___ Anybody know if these are reproduced? Thanks!!
You get those from www.cowlplenum.com (http://www.cowlplenum.com/) at $2,400 a set up.
BonzoHansen
02-18-2010, 06:47 PM
So what makes that $1300 better than the one CL listed??
Stg1Regal
02-19-2010, 05:26 AM
Dunno.... just had that link in my computer.
They do look the same......
Been looking to do a similar set up myself , on my 82 Buick Regal, since I'm heater & a/c delete, to kinda give it a Trans-Am,NASCAR-ish, road racer appearance under the hood, was going the deep cake pan or deep chillie pot route, and then going to do my own duct work, also would have to go to www.cowlplenum.com (http://www.cowlplenum.com/) and get the flexible ducting piece.
But CL's link http://taperfresto.com/cowl_plenum_a_c.html seems much easier and less exspensive.
Charley Lillard
02-19-2010, 06:40 AM
That wasn't my recommendation.
Stg1Regal
02-19-2010, 07:05 PM
Charley Lillard
My bad .. sorry wasn't paying attention to my quotes...
It should go to ......BonzoHansen
Sorry guys
