View Full Version : 72 Chevelle Air suspension choice
Foxchapeliron
02-05-2010, 01:10 PM
I had just done a thread on whether to use drop spindles with a Ride Tech air system. Got that answer, Thanks.
The other question was has anyone used the Ride Tec system vs the Air Bag It system? There is a big price difference due to the air bag it system using stock a arms and such but the shock relocation is going to be tight. If anyone has good or bad to help out I appreciate it!
marolf101x
02-07-2010, 02:16 PM
All I can say is I suggest you use the following (regardless of supplier)
-trusted air spring manufacturer (preferably one who has sold millions of air springs and tested them into the tens-of-millions of cycles)
-DOT approved EVERYTHING! If you skimp on air line, fittings, valves, etc you'll be disappointed, and UNSAFE! The DOT has mandated specifications for all these parts as all semi-tractor rigs on the road use air brakes. If the brakes fail, it's a big deal.
I'm not saying to buy one kit over the other, I'm just suggesting you do some research to ensure you get the best parts for your money. I don't want anyone unhappy, and I sure as hell don't want anyone put in harms way!
ProdigyCustoms
02-07-2010, 02:48 PM
For Air Suspension, We only sell RideTech. No one else puts their stuff through the torture Ride Tech does.
