View Full Version : Axle Code
LONE*STAR
01-22-2010, 07:20 PM
Code : BP 02 03 W
I just pulled this from my 67 bird to give the c5 makeover, axle tube end to end is 57". Thanks
01-22-2010, 10:42 PM
Give a look here, is that a stamped code? The raised code on the center section is a casting date, does not indicate ratio, etc.
http://firstgenfirebird.org/FAQ/wheel_brake_axle/axles.html
LONE*STAR
01-23-2010, 12:38 AM
Thanks Dave,
That is the stamped code on the passenger side axle tube, the pumpkin has parallel reinforcements and is a ten bolt. On the pumpkin there are cast numbers GM63 with a zero over it, and on the opposite side 3894859NF
LONE*STAR
01-24-2010, 01:06 AM
Any one have an Idea what Im dealing with here??
Does the raised casting GM63 on the passenger side of the housing indicate it was produced in 1963??
Z06vet
01-24-2010, 05:28 AM
I only have a camaro code sheet, but BP is listed as 2.73 non posi. U can just pull the cover and count the teeth if you want.
-DA
01-24-2010, 06:41 PM
http://www.camaros.org/drivetrain.shtml#AxleCodes
dig through that link for more than just the spreadsheet of axle codes. it seems the BP code was used for 3.08 open diff 10-bolts in '67, not just as 2.73's in '68-9. like David Pozzi said the date codes is cast on the center section... that link will show you everywhere to look and how to decode it as well.
-Dave
LONE*STAR
01-25-2010, 01:24 AM
does GM63 on the center section indicate 1963 production. I already know the ratio and traction unit. I'm trying to figure out if this is even the original rear end.
