    Results 1 to 4 of 4
    Thread: will they rub
      california
      will they rub
      i followed all the rules did the measurements am running a 18x9.5 rear rim a 18x275x40 rear tire the rims have 5.5 back spacing . using the detroit speed rear multi leaf 2 inch drop springs after re centering the rear end in the car i have maybe 1/6 of an inch clearance between the fender well lip andthe tire . will it rub .? had to remove the bisc brake brackets and go to an inner axle mount to get the tires inside the fender lip.. some one help. if u have a similiar set up please e mail me some pic,s of your tire to fendder lip clerance to [email protected]
      thanks
      Kiler wisconson
      Should fit perfect... PROTC has 17x9.5s (5.5 BS)on the rear of his 67 camaro with 275 40 17s and it fits great..
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
      california
      hmm mine are like real close say maybe 10 piece,s of binder paper inbetween tire and lip offender
      Sep 2004
      Metamora, Illinois
      It is not uncommon to have to roll the lip of the rear quarter wheelwell to allow for proper fitment.
