    Results 1 to 10 of 10
      IN/MI border
      2nd gen vs 3rd gen camaro steering box??
      What is the basic difference between the 2 power steering box's? Is there one that is better than the other to use on 1st gen Camaro? I want a tight ratio around 2.5 turns lock to lock.
      Mesa, Az
      For that you should go with the variable ratio box and a quick ratio pitman arm. I'm not sure if it will get it down to 2.5 but it should be close.
      Central CA USA
      2nd gen box is 14 to 1 ratio, the later 70's boxes had stiffer feel than early boxes. Variable ratio boxes were discontinued in the late 70's in favor of constant ratio.
      Third gen boxes have metric ports with O ring seal, Z/28, TA, IROC have 12.7 to 1 ratio.
      A 2nd gen box with long pitman and shortest outer steering arms will give you very close to 2.5 turns lock to lock.
      Jun 2002
      Benicia, CA
      3rd Gen Quick Ratio
      Quote Originally Posted by BuddyP
      Many years ago a pro box builder (Nascar, Winston Cup, show cars, etc.) told me that it would be easier and cheaper for me to replace my 2nd Gen box with a 2rd Gen quick ratio box than to have him build me one. He told me to find a 3rd Gen that had the special-order quick ratio box, and I found one with less than 20k miles. Installed it has 2.25 turns lock to lock, all I had to do was use my original pitman arm and have the supply hose made with a metric fitting to fit the newer box.
      Jeff
      1971 RS Camaro: PAINKILLER
      Dunwoody, GA
      i believe he was referring to a "Z" box. they were availible in IROCs and GTAs not all of them had that box fi i remember right, but if you find an IROC or GTA look at the steering box. it will have a "Z" stamped in the side of it. there is a company that sells these boxes already rebuilt with adapters so that you dont have to have custom lines made. email me if you want me to dig it up. i have it somewhere.
      Trey
      ~ Jon Hammond
      Central CA USA
      I too have a box off of a 3rd gen I plan using on my 80 camaro. It is the quick ratio off of an IROC Z. payed 50 bucks for it and a 1 1/4 sway bar from a TA along with some other small misc. pieces. hydraulic lines shouldnt be a problem just find a good parts store that can make a custom hydraulic line or use the lines and pump off of the 3rd gen.
      Nov 2004
      dayton ohio
      my 2 cents
      hey david (or anyone else)if i get the 3rd gen box (w/metric fittings) what are the odds that an ls1 power steering pump and hoses will hook up? im going ls1 anyway. thanx joel
      North Jersey
      The quick ratio 3rd Gen box should be stamped "XH". While they will give you around 2.5 turns lock-to-lock, they also have different internal stops that limit travel somewhat. They did this from the factory to keep the larger 16" wheels from hitting the steering stops.
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Central CA USA
      I'll bet the LS1 pump will work.
