View Full Version : AFX spindles with Strong Arms
dhutton
12-22-2009, 05:39 AM
Anyone running these together with Shockwaves? I was thinking of going this way on my 64 GTO. Did a search but didn't find much, only a brief reference to Vinnie's Camaro.
Thanks.
killer69
12-22-2009, 08:10 AM
there is no reason they won't work! still need the original steering arms
dhutton
12-22-2009, 08:25 AM
I'm not following you on the steering arms. I have the ATS billet A body steering arms so I was assuming that they would work. Or are they too big?
Thanks.
MuscleRodz
12-22-2009, 09:05 AM
I don't think Blake caught that you have an "A" Body. We are building a Camaro with this setup right now. No problems since Air Ride designed it to work with stock spindles.
dhutton
12-22-2009, 02:09 PM
Thanks Mike. Are you using the Shockwave for the stock spindle or the tall drop spindle?
cwylie
12-22-2009, 02:21 PM
Why not use the airride tall spindles?
130fe
12-22-2009, 03:23 PM
I have the strong arms with the ATS spindles on my 68 camaro. The only issue I ran into was having to send the shockwaves back to ART so they could install a longer shock (due to the 7/8" drop with the spindle). Apparently they offer 2 different length shocks and I had the wrong one. I had the "standard" length shock and was only getting 4 inches of travel, now I have almost 6 after swapping it out. I have to blame myself for that (for not doing enough research), its one of the issues you can run into when mixing up parts from different manufacturers. I wasn't getting full travel and was having to put to much air (120psi) to get the "proper" ride height causing a bouncy ride. Now with the longer shock I have more travel and it rides great (with lower air pressure- 90). The ART tech guys and Frank @ Prodigy have been awesome in helping me figure out some issues I had with the system.
garickman
12-22-2009, 04:16 PM
Chris,
I am glad I read this thread. I am just getting ready to install my new shock waves on my '68 with ATS spindles. I am assuming since I did not specify, I too probably have the "standard" length shock waves. Is there any way I can tell.
Greg
dhutton
12-22-2009, 04:39 PM
Chris,
Greg
The standard part is SKW1036 and the tall part is SKW1038. Normally you only get the SKW1038 when you buy their tall spindles.
dhutton
12-22-2009, 04:42 PM
Thanks Chris. Sounds like I will need the tall part.
cwylie, I am using the AFX spindles because I already have them. I chose them for their low bumpsteer design (with the ATS steering arms) and the ability to bolt on C5/C6 brakes. I think they are a very well designed part.
MuscleRodz
12-22-2009, 10:16 PM
We are running the tall AFX spindles. I have to check but should have the long Shockwaves as we originally had the Ride Tech spindles and upgraded to AFX for geometry gains and cheaper brakes.
killer69
12-23-2009, 09:46 AM
yea sorry totally missed the "64 GTO " part yes you neeed the steering arms and i see you have them. sounds like your good to go.
gggoad
01-21-2010, 01:54 PM
I have them in my Camaro as well - also had to send the shocks back, but I had to have a shorter towers because the car wouldn't sit low enough! I am having some issues with the ball joints in near bind at ride height and the upper control arms are at a steep angle. I have been told I may have to go back to stock spindles. Going to wait to see how it drives before making a decision.
