View Full Version : Hydroboost problem
Scott Norris
12-14-2009, 05:13 PM
Hope someone can help me with this,I purchased a Hydroboost Direct from Hydratech a few years ago and just now getting the car running.When I started the car it did not even reach operating temp and the PS fluid was 246 degrees.Started checking lines and there is no circulation through thru the HB unit.It just deadheads and gets hot.No dealer has any idea and no way to contact Hydratech.Does anybody have an Idea or know the part # for a off the shelf replacement? Thanks
terryr
12-15-2009, 10:10 AM
Like someone always says, are the lines hooked up properly? Does it do it with the brakes depressed?
Before buying another you can take apart that one. It's all rubber gaskets and pretty easy. Can't make it worse.
scogin918
12-15-2009, 05:00 PM
Try (615) 449-8261. I just found the number when I googled their name.
Hydratech®
12-16-2009, 07:20 AM
http://www.lateral-g.net/forums/showthread.php4?t=24189
