View Full Version : longer studs for 69 f body
69projectKAOS
12-12-2009, 10:35 AM
can someone find me a link for longer studs for my 69 camaro, i have a set of wheels that fit perfect and the backspacing is fine but the studs are not long enough to get a bite with the lug nuts thanks-dom
mm065
12-13-2009, 09:20 PM
Jegs!
JustinB
12-13-2009, 11:05 PM
We could also order you a set.
Apogee
12-14-2009, 06:49 AM
You can buy a OE replacement, overlength stud for your application...Dorman #610-157. It's a 7/16-20 press-in stud with a 2-1/8" under head length.
If you want to upgrade to M12 or 1/2-20, there are limited options without needing to resize your hub/axle flange wheel stud holes, so I would typically plan on some machining if you choose to go that route.
Tobin
KORE3
69projectKAOS
12-14-2009, 08:39 PM
thanks guys, i found a set on jegs, i should have looked first :idea: thanks-dom
