View Full Version : Wow fianally found a converter
MonzaRacer
11-29-2009, 08:54 PM
Finally found a converter for my variable pitch turbo 400, WOOHOO. Had this trans since 1986, tried to save for a Nunzi converter but they went under I guess. So been looking ever since.
Gotta get trans apart and see if sitting has damaged anything.
Think of it, a converter that has 2 stall speeds! Tight for mileage and loose (high stall) for performance!
Now if built 400 didnt get hurt sitting also. May need a trip to Bowler soon!
4086D9
11-29-2009, 11:34 PM
PAE and trishield both make switch pitch converters. Check them out!
Jake's Performance
11-30-2009, 01:21 PM
I have two complete switch pitch setups for TH400s.
One has a Pro-Torque 3000 converter, the other is a PAE 4000 setup.
The PAE setup is $450 and the Pro-Torque setup I would sell for $300.
MonzaRacer
12-02-2009, 10:40 PM
Hey on the pro-torque , is that a 3000 stall on the high stall or low stall?
4086d9 do you have a link to trishield?
The converter i am looking at is basically a stock one, stock would be in 1200-1400 low and 2800 to 3200 on the high depending on the torque production involved.
Jake's Performance
12-03-2009, 07:42 PM
The Pro-Torque is 3000 in high stall.
Nessumsar
12-03-2009, 09:17 PM
How do you switch them, do they make one for the 700r4?
Socrates
12-11-2009, 09:13 AM
I highly reccommend PAE (www.paeenterprises.com) for the switch pitch stuff. Really nice and knowledgeable owner, a great product and they have been around forever. I had one of their SP400's built for 800+ HP and a 1400/4000RPM converter. I activated the high stall with the brake pedal/lights. More fun then an auto car has a right to be !
