    Results 1 to 4 of 4
      Feb 2009
      So-Cal
      How to wire electronic speedo?
      Hey guys, I am doing a swap in a 65 Buick Skylark. I am using a LT1 and 4L60E. I found a great deal on a set of electronic gauges and I don't understand how I would wire in the speedo. I haven't bought the gauges yet because I wanted to know if I could wire in the speedo first. This car doesn't have wheel speed sensors like the car I took the motor and trans from so I'm kinda lost. The gauges are from tpigauges and look really great and have that classic look. Any one with some insight I would greatly appreciate it. Thanks
      -Jeremy
      65 Buick Skylark: Getting a LT1 and T56
      95 Camaro: DD commuter project, LT1/T56/T-Top swap
      07 Kia Spectra: Current commuter
      Dec 2000
      NE Florida
      elec speedo
      The 4L60E will (should) have a vehicle speed sensor (VSS); These normally have 2 wires that feed the speed signal to the ECM. You can tap into that, or the output signal from the ECM. Either way- you can use the signal from that & then calibrate the speedo. Autometer has you run a certain distance to cal it- it's pretty easy.
      Jun 2001
      Newbury Park, CA
      I use the ECM signal to drive the speedometer. Your tuner can change the ECM prameters to get it close, then use the Autometer calibration proceedure to get it spot-on.
      Feb 2009
      So-Cal
      Perfect. This is exactly what I was hoping for. Thank you so much. I appreciate it.
