View Full Version : body mounts
marty69212
11-27-2009, 05:23 PM
i am getting ready to purchase body mounts and was wondering what everone is using. also is anyone running the shorter ones vs the factory height mounts. what problems would irun into with the lower ones? i was looking at speedtech.
redfire69
11-28-2009, 05:58 AM
Stock height solid global west. I've read the reduced height are not worth the troubles they cause with trans tunnel and inner WW clearance.
marty69212
11-28-2009, 11:59 AM
thanks for the quick reply. i was looking at those also, seems you cant beat the price!! thanks again
Jasons72
11-29-2009, 07:12 AM
I run the global west half inch drop mounts and have ZERO clearance issues. Your old mounts sag/shrink anyway, when i installed mine i actually didn't lower anything since mine were so far gone.
protour73
11-30-2009, 05:26 PM
pro-touringf-body.com GenII 3 in 1 "shear-proof" solid body bushing http://www.pro-touringf-body.com/chassis_components.html
stock height setup, the lowered setting would have put my Tremec TKO600 into the trans tunnel.
I installed these with Grade 8 Stainless Steel hardware from Totally Stainless http://www.totallystainless.com/2009catalog/catalog34.pdf
https://static1.pt-content.com/images/pt/2009/12/new_body_bushings181x125-1.jpg
amargari
11-30-2009, 07:07 PM
I am running the stock height Global West units. I have also heard great things about the pro-touringf-body.com ones too.
