View Full Version : "How to" carbon fiber dash panel for 2nd gen bird. Anvil, Autometer, Vintage Air.....
NOT A TA
11-18-2009, 08:57 PM
I recently built a custom carbon fiber dash panel assembly to fit in the stock 2nd gen dashboard of my friend Tys car, "Freedom Bird" which is being built at Fletchers Customs. The panel was made using Anvil Auto carbon fiber. Installed in the panel are, Autometer Cobalt gauges, Vintage Air controller, American Autowire headlight/lights switch, NOS arming switch, Pypes exhaust cutout switch, aftermarket delay wiper switch, and topping off everything is a set of Twist Machine billet gauge bezels.
This thread will detail the "How To" so that anyone who wants to create a custom panel for their own car can see how it was done. The same procedures to fabricate and mount the panel could be performed using other types of materials for the panel. Below are a few pics of the panel as it was installed at the SEMA show.
A few things are not quite finished in the pics due to a show deadline and pieces which had not arrived in time for the show. A shift light will be installed in the space under the gas gauge between the Tach and Speedo, a billet bezel for the wiper switch, different toggle switches and a small "bird" emblem in the space next to the VA controller. The last post containing instructions in this thread will list the companies websites as well as tools and other things needed to complete the operations.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild082-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild2431-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild241-1.jpg
https://static1.pt-content.com/images/pt/2009/11/SANY0053-1.jpg
NOT A TA
11-18-2009, 09:00 PM
The first thing you need to know is that this is not a quick project. If you don't have a lot of patience for detailed time consuming work stop reading now, just enjoy the pictures.
For the purpose of these instructions the gauge panel assembly and pieces will be refered to as follows
Bezel: The aluminum trim ring that surrounds the part with the gauge openings.
Facia: The flat part with the gauge holes in it.
Hood: The stamped sheetmetal section that has 3 screws holes where the upper part of the assembly is screwed to the upper dash.
Panel: The Bezel, Facia, and hood attached to each other as an assembly
The first step is to remove the hood from the panel. This is accomplished by filing or grinding off the heads of the rivets holding it to the panel. Don't try drilling them out, it doesn't work well.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild018-1.jpg
Once the hood is detached, remove the 2 screw clips on the bottom of the panel where the screws that come up from the bottom hold the panel in place when installed in the dash. Be very carefull not to bend or twist the bezel which might deform it enough to see from the front after reassembly. I find the clips are most easily removed using a dental pic and small pair of needlenose pliers. PUT THE TWO CLIPS SOMEWHERE YOU WILL NOT LOOSE THEM!
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild019-1.jpg
NOT A TA
11-18-2009, 09:03 PM
The Bezel has several folded over tabs which hold it to the facia. These tabs need to be VERY GENTLY straightened out. This allows the bezel to be separated from the facia. Remove the bezel and put it in a safe place where it cannot get bent.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild020-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild021-1.jpg
Wiggling the individual gauge rings will allow them to be removed from the facia. Also remove the Radial Tuned emblem. Once this is done get a piece of posterboard and lay the facia on it face down. Then put a heavy weight on it to keep it still and hold it flat to the bench.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild022-1.jpg
Use a pencil to draw an outline of the facia and all of the stock openings on the posterboard. It is important to mark all of the openings of the stock controls for reference when aligning things later. The panel does not have any straight lines on the circumference and even openings like the heater control section are not a perfect rectangle. all of the elements of the dash were figured out to make everything seem straight and level from the drivers position. Whoever designed the original dash did a fantastic job and must have put a tremendous amount of thought into the layout and design.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild023-1.jpg
NOT A TA
11-19-2009, 09:11 AM
Very carefully cut the shape of the facia out of the posterboard along the inner edge of the circumference line you made. Do Not cut out any of the openings for gauges etc. Sand the posterboard until you have an exact fit within the bezel. If you are off more than 1/16" you will have gaps where the posterboard does not fit perfectly into the bezel.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild026-1.jpg
Now lay the posterboard cut out onto a thin sheet of ABS you'll be using for mock up. (If you're really confident in your skills and plan you could skip to the carbon fiber or final material you are going to use but I recommend fitting everything with cheap plastic first.)
Tape the posterboard in place so it cannot move and trace the outline onto the plastic with a grease pencil. Then remove the posterboard and cut out the facia shape using a Dremel with a cutting bit. Do not try to cut it exactly to the correct size. After you've cut the shape out, sand down to its final size using 80 grit paper to fit perfectly into the bezel. The plastic shown in the pics is fake carbon fiber. It's very realistic looking but does not reflect light with the same prism effect of the real stuff.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild028-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild032-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild034-1.jpg
NOT A TA
11-19-2009, 04:58 PM
Now its time to plan where the new gauges will be placed. Use a ruler to line up the original gauge openings and locate the centers of the original openings. Next use a caliper to measure the outside dimension of the gauge trim ring on your new gauges and use a compass to mark the posterboard with the outline of the outside of the new gauge trim ring. If you are using 5" Tach and Speedometer units this will allow you to see if the tach needs to be moved toward the column a liittle to gain clearance because of the taper of the facia.
The Autometer 5" gauges aren't really 5" anywhere you measure them. I guess they call them 5" because they're about 5". Once you've determined where you'd like the Tach and Speedo positioned measure the gauge body right behind the trim ring and use a compass to mark the posterboard where the hole the gauge will need to fit into will be cut.
Next do the same thing for the slmaller gauges. If you're using the 5" - 2 3/16" combo then the gauge between the tach and speedo looks better if you raise it and the 4 side gauges look better spread out a bit.
Once you're sure where you'd like the gauges, cut out the holes from the posterboard.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild053-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild039-1.jpg
NOT A TA
11-19-2009, 05:03 PM
Use some 80 grit paper to sand the posterboard till each gauge fits into the hole. Keep in mind that the housing of each Autometer gauge is tapered a little from front to back so just because you can fit the back of the gauge into the hole you'll still have to widen the hole till you can slide the gauge housing all the way in to the hole until the gauge trim ring contacts the posterboard. Cut out the holes for the AC vent and lighter opening. The lighter opening needs to be oversized a little to allow variances when the final panel is installed. The trim ring for the lighter will cover gaps.
Once you've got the openings finished lay the posterboard onto the plastic panel and tape into place. Mark all openings with a grease pencil and cut openings with a Dremel tool keeping in mind not to open the holes up to much. You will sand the plastic to fit after cutting with the tool. I use something round to be sure I don't end up with egg shaped holes.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild055-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild056-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild057-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild058-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild062-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild069-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild060-1.jpg
1badchevelle
11-19-2009, 07:40 PM
Good job I may try this. for my chevelle.
markd
11-19-2009, 07:50 PM
Great idea on posting a “how to” thread!
This will help me out when I start my own insert/gauges in December.
Thanks! :cheers:
NOT A TA
11-20-2009, 08:36 AM
Thanks! :cheers:
Thank You! While this is about a Firebird dash a lot of the techniques can be used on many other types of dash panels so I hope it helps a lot of people over time when they're planning or building a custom panel.
.................................................. ...............................................t
This dash panel will be using a Vintage Air (refered to as "VA" from now on) controller to operate the VA AC and Heat/defrost system. If you are using a stock heater control panel, mark the opening on the posterboard, cut, and then transfer to plastic and cut. If you are using a VA controller you will need to find the centerline of the original heater control panel by measuring on the posterboard and drawing a line. The line is used as a guide to keep the VA controller straight when deciding where you would like the VA controller positioned. Keep in mind that the circuit board assembly on the back is larger than the face plate and you have to keep the whole assembly high enough on the facia to provide clearance for the circuit board.
Once you've decided where to mount the VA controller place the face plate on the posterboard and mark the opening. Cut the opening on the small side and then sand the cardboard to an interference fit. It is important to the finished product that the hole for the face plate be exact. If the hole is too big the face plate may be able to slide around in the hole because of the way the face VA assembly sandwiches the facia to hold it in place. Once you have the VA controller opening where you'd like it, place the posterboard on the plastic panel and then repeat the process on the plastic.
Vintage Air provides a template in their instructions for people installing their controllers in places where the template would make it easier to locate the face plate. For this installation I would recommend not to use the template but rather just trace the actual face plate where it fits in the facia.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild110-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild109-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild113-1.jpg
CruizinKev
11-20-2009, 08:52 AM
very nice :twothumbs
Steelrat
11-20-2009, 03:38 PM
very well done :1st:
What console is that in the car? Camaro?
NOT A TA
11-20-2009, 07:39 PM
Thanks! It's a repro that looks like it was intended to allow it to be used in Camaros or Firebirds. It doesn't have the correct brackets to bolt it to the dash like the stock ones do.
If you are mounting switches to the dash. The space to the right of the lighter is an excellent place, and is where the factory installed switches in some models. There's clearance behind the panel in that area for wiring. Now is the time to locate them on the posterboard and follow the steps to transfer their position till you have the holes drilled in the plastic to mount them. Turn signals also need to be located and holes made for them at this time. If you are using LED turn signal indicators be sure not to place them where they cannot be seen while driving. You don't want one or both blocked by the steering wheel etc.
I get an assortment of switches and return most of the switches quickly. I hold them up to the facia, gauges, and other items to see what will look the best. In this case none of them were "perfect" so the black with blue LED "on" indicator switches will be replaced with some billet ones to match everything else later. Sometimes you win, sometimes you don't! LOL The round blue NOS switch in the pic below is a momentary switch that will be mounted in the console to operate the line lock. The two "on/off" switches placed into the panel on this dash are going to operate the NOS arming mechanisms and the PYPES electronicly controlled exhaust cutouts.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild156-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild160-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild162-1.jpg
NOT A TA
11-21-2009, 07:46 AM
Now its time to set up the wiper and headlight switch area. The lights switch provided with an American Autowire update kit is the same mounting and wiring setup but has a cool chrome switch shaft and billet aluminum knob. Because it uses the same mounting and the same wiring connector as a stock original I'm using an old light switch in the mock up pictures and will install the new switch in the newly reconditioned dash from Restore a Musclecar when the dash and panel are installed in the car.
If you are using a stock wiper switch cut the light switch and wiper openings out of the posterboard, check to be sure everything lines up in the actual dash, then transfer to the plastic sheet with the grease pencil. Then cut and finish the openings.
The aftermarket delay wiper switch is more of a challenge. The kit is made for Camaros of the same vintage and the mounting bracket provided will not work in a Firebird dash. A new bracket has to be made. The original wiper switch face was recessed into the dash. Because the front of the new carbon fiber facia will be out farther from the dash the bracket has to bring the new switch out far enough so the base of the switch shaft will end up flush with the backside of the carbon facia. A trim ring screws on the switch shaft after the panel is installed in the dash to cover the hole around the switch shaft.
The dash framework under the wiper switch has to be clearanced to fit the bigger switch into the area where the old sliding switch was. Use a hand held hacksaw blade holder to cut the dash plastic then break off the pieces with pliers. If you try to move the wiper switch higher you will not have enough space for the light switch wiring harness which plugs into the bottom of the light switch. The camaro bracket is on the left and our new fabricated bracket on the right.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild144-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild137-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild138-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild148-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild139-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild145-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild151-1.jpg
NOT A TA
11-22-2009, 07:07 AM
At this point you should have a plastic sheet with all of the openings you'll need for gauges, switches, turn indicators, and the vent. You can put the bezel on the plastic sheet and test fit it one last time in the dash. If everything looks good it's now time to use the plastic sheet as a template to mark the carbon fiber sheet that will be the new facia. The sheet comes with a protective coatiing on it. If you can't see through the protective film well you can remove enough of it to examine the carbon fiber for imperfections etc. in the weave. Most of these sheets are laid up by hand so there are minor variances in the appearance. Its not like the fake stuff with a perfect look. Also there may be minor scuffs or scratches from handling even with the protective coating. Minor scuffs or scratches can be fixed later if necessary by scuff sanding the surface then clear coating and polishing. Pick the nicest looking side and then lay your plastic template on it trying to line up any imperfections where they will end up where an opening will be cut out. Tape the plastic in place and mark the carbon sheet with a grease pencil.
Cut the carbon fiber panel out of the sheet with a cutoff tool. Wear a respirator and eye protection. You may also want to wear latex or nitrile gloves as the fibers may irritate skin the way fiberglass does. You can not cut the carbon with a Dremel tool so forget even thinking about trying it. This is tough stuff as you're about to find out.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild102-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild104-1.jpg
NOT A TA
11-22-2009, 03:49 PM
Now you need to file and sand the Carbon fiber (refered to as CF from now on) facia till you have an exact fit in the bezel. A fine toothed metal file works well to rough it in and then and finish with 80 grit sandpaper. When you think you've got the fit correct put the CF facia in the bezel and then put the original stock facia behind that and use some clamps to hold everything. This way you'll be able to check for a more exact fit.
The center area by the steering column can not be taller than the original facia or it will be very difficult to install the completed panel in the dash. It is easy to end up with the center of the panel too tall and have it still fit in the bezel when you are fitting it without the original bezel in place because of the flexibility of the bezel. If it is too tall there it will also be difficult to pop rivet the completed assembly together later so be sure the CF panel is exact.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild088-1.jpg
NOT A TA
11-22-2009, 03:59 PM
Now that you have the CF facia outline finished it's time to make all of the other openings. First cover the front side with masking tape so you don't scuff it or scratch it up. Cut the holes for the gauges with a hole saw using a drill press. Make sure you have wood under the CF facia and clamp it down when drilling. You will need Bi-metal hole saws to cut the holes. If you're using the 5" and 2 3/16" gauges you will need a 4 1/4", a 2 1/8", and a 1 1/8" for the lighter and headlight holes. Once the holes are drilled you will need to file and sand the openings to the correct dimensions.
You can cut out the vent and Vintage air controller openings with the cutoff tool and then file and sand to finish.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild118-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild107-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild108-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild115-1.jpg
NOT A TA
11-23-2009, 06:17 AM
With the openings completed you will now be able to modify the original facia which will be used to provide support and allow assemble of the new panel. The idea is that the new CF facia will be sandwiched in between the leading edge of the bezel and the original facia. This is what holds the new CF facia in place, provides for stock mounting fasteners to be used , and allows you to use the bezel which gives the new panel the "look" because of the outline it creates around the CF panel.
Lay the CF facia on a bench and place the stock facia on top of that. Then you will see where you need to cut the stock facia to allow the gauges etc. to protrude through. You can cut the stock facia with a cutoff tool and then file to make it look neater and get rid of sharp edges you might get cut on or that might nick a wire. Be sure to leave vertical supports, do not cut out everything but the outside edge.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild117-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild119-1.jpg
NOT A TA
11-23-2009, 07:07 PM
With the original facia now clearanced you can assemble the bezel, CF facia, and the modified stock facia then clamp them together. This will allow you to mock up the panel and have some fun seeing what your new dash is going to look like.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild121-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild127-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild130-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild133-1.jpg
NOT A TA
11-23-2009, 07:18 PM
Now that you've had a glimpse of the future for your dash it's time to get back to work.
Take everything out and put all the gauges back in the boxes except one of each size along with one bracket for each that holds the gauge in place and 2 nuts, no need for lockwashers. Take the original facia and bezel off. Use some wax and grease remover to clean the original bezel in the area surrounding the vent hole then paint it flat black. You only need to do the area around the vent because the rest will be hidden but if the vent area is left shiny or wood tone you'll be able to see it after the panel is inserted into the dash.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild164-1.jpg
DallasLatino05
11-24-2009, 01:55 AM
very nice job
NOT A TA
11-24-2009, 04:31 AM
Now it's time to modify the dash structure for clearance for the gauges. You should put some masking tape around the edge of the CF panel because you will be putting it into the dash several times to check for clearance of each gauge. Do not try to assemble the pieces of the new panel yet. ONLY USE THE CARBON FIBER FACIA WITH ONE GAUGE AT A TIME TO CHECK CLEARANCE.
In the pictures below I put white paint on the areas of the dash framework where you will have to cut the plastic away. It is much easier if your dash is out of the car but if it is in the car it can be done, it's just more of a pain to work in there.
You can use a fine toothed hacksaw blade with a hand held blade holder to cut the plastic and then break out chunks as you work your way across the area where the panel fits into the dash. Once you think you've got it set then install one gauge with the retaining bracket screwed onto it in the CF facia and place the facia into position to check clearance for that gauge. Repeat for all gauge openings.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild201-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild202-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild203-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild206-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild208-1.jpg
NOT A TA
11-24-2009, 04:33 PM
Once you've got the dash clearanced you need to set up the lighter bracket assembly. The bracket itself needs to be modified to provide clearance because it has to move out from the dash to meet the new CF facia. When the bracket moves forward it will contact the bezel so it has to be notched as shown in the pic below.
Next you need to space the lighter bracket out away from the dash panel. The reason for this is because the new cf facia is flat and the original facia was recessed around the lighter. You can do this by getting some 1/8" rubber hose and cutting three 3/8" pieces off of it. Put the little hose sections on the three screws that hold the lighter bracket in position and reinstall the bracket. Do not overtighten or you will crush the pieces of hose.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild220-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild172-1.jpg
NOT A TA
11-24-2009, 05:37 PM
Well you're almost ready to assemble the new panel but first gently clean the bezel with some metal polish and repaint the hood. Use some wax and grease remover on the hood, sand the hood with 400 grit and then spray with SEM trim black. Use a black magic marker to black out the cut edge of the carbon fiber of the lightswitch hole and where the vent opening is. Repaint the trim bezel for the lighter that screws on from the front after the panel is installed into the dash.
Now lay the bezel, CF facia, and modified original facia on the bench and use clamps to hold it into position. Gently bend the tabs over that hold the bezel to the facia. It's important to make sure the three pieces are tight when you fold over the tabs. Take your time, be very carefull, and don't screw up! You only get one chance! Rebending the tabs again will probably break them off. GM only designed them to be assembled one time. If you should break off one of the tabs carefully cut a new tab with a hacksaw blade close to the broken one.
With the tabs folded over stand the facia assembly upright and you'll notice the pop rivet holes where the hood attaches don't line up quite perfectly anymore because of the thickness of the cf facia. Use an awl to widen up the hole in the bezel so the new 1/8" pop rivets will fit. Do not make the holes any wider than necessary to insure the bezel , cf facia, and original facia stay squeezed together tightly. Then place the hood on the facia assembly and pop rivet the pieces together with the 1/8" rivets. I add a couple extra rivets in top areas around the bezel before adding the hood to make sure everything stays tight and you're not counting on the (now weakened) fold over tabs. Be cautious on placement of the extra rivets as they may cause an interference problem.
YOU NOW HAVE A CUSTOM CARBON FIBER DASH PANEL !!!!!
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild179-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild174-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild177-1.jpg
NOT A TA
11-25-2009, 02:22 PM
With the new panel assembled it's time for a final mock up of the panel. Install all of the gauges, switches, turn signal indicators etc. If you're lucky enough to have a spare dash to work with like I do, you can mount the switches and Vintage Air controller first, then put the panel into the mock up dash and install the gauges. If not, you can install everything and align the gauges so they are straight. If you are using the Twist Machine bezels you can position them to see how it will look but wait until the panel is installed into the dash for the final time before mounting them with the small removable silicone "dots" they come with that hold them in place.
Stand back and admire your work! Relax a bit before getting ready to install the fully assembled panel into your dash.
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild170-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild182-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild184-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild198-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild199-1.jpg
NOT A TA
11-25-2009, 05:09 PM
The new light switch from American Autowire needs to be installed into the dash now. You will need to disassemble the original light switch assembly to transfer the bracket and trim bezel over to the new switch. The new switch comes with a nice billet knob and a shaft you can cut to length for your dash. If you'd like to keep an original appearing knob and shaft they can also be used with the American Autowire switch. Once the switch is installed into the dash, plug in the electrical connector. There is very little space between the light switch and the larger aftermarket delay wiper switch after the panel is installed. Also, who wants to lay under the dash trying to do it afterward anyway?
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild221-1.jpg
You're now ready to test fit the fully assembled panel into your dash. Because the original panel was installed without gauges and other items sticking out of the back, you must be very gentle and cautious installing the new panel. Wrap some protective sheeting in the area where the panel slides in to prevent scuffing or scratching the vinyl. This is particularly important if installing to redyed dashes. DO NOT USE MASKING TAPE ON THE VINYL OF A REDYED DASH OR YOU MAY PULL THE DYE OFF WHEN REMOVING THE TAPE!
To install the panel tilt it so the bottom goes in first and gently tilt up little before the speedo and tach contact the framework. Then push the panel straight back and the panel should settle into it's original position. In this installation we're installing the panel into a reconditioned dash from Restore A Muscle Car so I clearanced the dash on a work table and will do the final fitting to check everything before we mount the dash in the car. Restore A Musclecar are my kind of guys! They packed the dash very, very well to protect it from damage in shipping. Since we already covered clearancing the dash structure to allow the new panel lets move on!
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild216-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild217-1.jpg
https://static1.pt-content.com/images/pt/2009/11/FirebirdTAdashbuild223-1.jpg
NOT A TA
12-01-2009, 05:11 PM
After checking the fit of the panel in the dash from Restore a Musclecar we installed the dash into the car and mounted it into position using a screw kit from Fbodywarehouse.com. Having a complete screw kit with all of the pieces individually bagged and labeled for each part of the dash and related assemblies is great for anyone who has lost any of the original nuts, bolts, screws etc. or for cars where previous owners have replaced the original hardware with whatever they could find laying around. Most of the 2nd gen cars have had portions or all of the dash apart over the last 30-40 years and people lost or broke some of the pieces. The Fbodywarehouse dash screw kit even contains the plastic T bolts that hold the plastic panel under the steering column, AND the inserts that fit into the dash framework that the T bolts insert into!
https://static1.pt-content.com/images/pt/2009/12/FirebirdTAdashbuild218-1.jpg
https://static1.pt-content.com/images/pt/2009/12/FirebirdTAdashbuild212-1.jpg
With the dash installed into the car it's time for the installation of the gauge panel. Each Autometer gauge has a wiring harness with a plug attached to it. Plug each one into the corresponding gauge and then coil up the wires for each gauge separately and install one of the labeling stickers provided with each gauge which names what gauge those wires are for. This way later on, when you're upside down under the dash trying to wire everything you don't have a big mess of wires to sort through trying to figure out which wires go to which gauges.
When installing the panel use some protective sheeting only on the ends of the panel where it is most likely to scratch the vinyl. If you use the sheeting all around you won't be able to see where the screw holes line up and it will be very difficult to remove the sheeting on the top and bottom with the panel fully into position.
Install the panel into the dash remembering to tilt the bottom in first, straighten it up, then push straight back. Once the panel is in position pull out the protective sheeting and then loosely install the three screws in the hood where it screws into the dash, then the two hidden screws that come up from the bottom of the dash. You can then loosely install the lighter trim ring, center up the panel where you like it, and snug up all of the screws. DO NOT OVERTIGHTEN!
If you are using a replacement screw kit the two long hidden screws that come up from the bottom may be Torx head screws. If they are Torx heads then tape a note to the back of the plastic panel under the steering column saying that they are Torx heads otherwise someone in the future will be going nuts trying to figure out why a phillips won't work up in there because its so dark they won't be able to see the heads. It might be you when you're old and senile and can't remember or a future owner but someone will be in there eventually. At this point in time we're just caretakers of these cars and the cars will probably be around after we're gone.
https://static1.pt-content.com/images/pt/2009/12/FirebirdTAdashbuild228-1.jpg
https://static1.pt-content.com/images/pt/2009/12/FirebirdTAdashbuild236-1.jpg
https://static1.pt-content.com/images/pt/2009/12/FirebirdTAdashbuild237-1.jpg
NOT A TA
12-01-2009, 05:20 PM
The Twist Machine bezels can now be installed on the gauges. It is a very simple, reversible operation.
The bezels are held in place by small silicone dots which are supplied with the bezels. Simply place a few dots around each ring and press the bezels into position. If you ever want them off you can just pull them back off with no damage to the bezel or gauge.
Once the bezels are installed it's time to sit back and enjoy your new dash panel. One hand on the wheel, making engine noises, and banging through the gears with the shifter is optional!
https://static1.pt-content.com/images/pt/2009/12/FirebirdTAdashbuild245-1.jpg
This list is all of the current websites for the companies whose products were part of the dash build for Ty's car.
http://www.anvilauto.com/
http://www.americanautowire.com/
http://www.autometer.com/
http://www.fbodywarehouse.com/fbw/home.php
http://www.twistmachine.com/shopping/
http://www.vintageair.com/
http://www.restoreamusclecar.com/index.sp
http://www.holley.com/index.asp?division=NOS
http://www.pypesexhaust.com/
Things needed other than basic hand tools.
pop rivet gun
spring clamps
drill and bits
grease pencil
markers
files
vice
ruler
compass
caliper
dremel and bits
cut off tool
hole saws
drill press
80 grit sandpaper
posterboard
body shop masking tape
clamps to hold work
spring clamps
amargari
12-08-2009, 09:10 PM
That dash looks awesome.
theYman
12-25-2009, 08:23 PM
Yes, that is awesome! I wish I could do something like this for my 69 Firebird. I dont think it would work on a 69 though.
jon72vega
12-26-2009, 03:33 AM
Nice work!
theYman
12-27-2009, 07:33 AM
I tried to find the carbon fiber faced sheeting on your link...Where did you buy it and how much was it? Is it just 1/8 sintra with a vinyl CF?
NOT A TA
12-27-2009, 05:13 PM
Thanks guys!
The real carbon fiber came from Anvil Auto, The fake plastic with carbon fiber printing on it I used for mock up came from a local car stereo installer.
lvrpool32
12-27-2009, 07:43 PM
Just as an FYI, 3M have out a new "carbon fiber" vinyl, its a dry finish (satin, not high gloss) but has a great 3G effect and unlike the other 3D vinyl's out there (they are normally polyestor and wont stretch) this stuff will bend and form with heat.
shoe4hire
12-28-2009, 08:37 AM
Wow!!
Smock67
01-08-2010, 05:21 AM
That is one impressive write up with a outstanding finished product. Kudos to you for taking on such a task.
Taman
01-08-2010, 06:56 AM
I like that. I think I might try to tackle that for my TA. What was the finished cost for the setup your running?
cdoggy81
03-24-2010, 08:44 PM
Turned out very nice :)
