Results 1 to 10 of 10
Thread: Mopar B body Rack and pinion
11-15-2009 #1
- Join Date
- Mar 2007
- Posts
- 9
I have a 66 Charger that I want to replace the steering on. I am considering the Unisteer Rack unit and an XV tilt Column. Anyone hear have any experience with a rack upgrade WITHOUT replacing the entire K frame?
1966 Charger, 452CID Stroker, TCI 727, 3.91, Fatman 2" Drop Spindles, 18" Torq Thrust
11-21-2009 #2
- Join Date
- Mar 2007
- Posts
- 9
Anyone?
11-21-2009 #3
- Join Date
- Apr 2005
- Location
- Colorado Springs
- Posts
- 761
Most of the feedback I've seen says the fitment isn't great, but tolerable. Biggest complaint is that turning radius will increase a decent amount because the rack does not have enough travel to mate up to the original steering geometry.
11-22-2009 #4I have heard about bump steer problems when you use rear steer spindles with a rack and pinion, although I am unsure why. I would be interested also, let me know what you find.
What would be really sweet IMO is a rack and pinion kit that kept the torsion bar arrangement.
11-22-2009 #5what sizes/offset wheels and tires are you running on that Charger? It looks very good with those wheels.
11-22-2009 #6
- Join Date
- Apr 2005
- Location
- Colorado Springs
- Posts
- 761
Bump steer issues are because the end links on the uni-steer rack are a different length than the tie rods on the original suspension, so they create a different arc of movement. Since most guys don't take the time to plot and correct this arc, the result is lotsa bump steer.
11-22-2009 #7
