Results 1 to 20 of 27
11-13-2009 #1
No road feel with quick ratio steering
The other post got me thinking.
I had my original steering box rebuilt by Lee with the quick ratio gearing. I also added an AGR pump. The steering is effortless.
I have been in other cars where the steering has more effort when you start turning and wants to jump back to center if that makes sense. This gives a nice sporty feel. I thought I recall reading a while back that this feel comes from some kind of torsion rod in the steering box, or is it the byproduct of how much caster you have dialed in?
11-13-2009 #2Caster will have an influence on steering feel, as well as torsion bars. Larger torsion bars will stiffen the steering by reducing the spool valve's opening rate.
Reducing system flow will also increase effort. Contact Lee to see what flow he recommends, then get a good quality pump with linear output (which excludes every OEM pump). KRC allows you to adjust flow to your liking and will greatly enhance steering feel by it's uniform flow. This makes a big difference that most people don't realize.
Another issue of feedback is system design. Drag-link type steering setups by design offer poor feedback due to lack of stiffness and stiction. Rack and pinions are much stiffer, thereby allowing more feedback to be transferred to the driver. Better yet, high-end racks are virtually friction-free. You can get some good feedback from a draglink system, but don't expect it to feel like a BMW.Matt Jones
Mechanical Engineer
Art Morrison Enterprises
11-18-2009 #3My point of refrence is how the late 80 Monte SS cars feel. That is what I was hoping to get. I think Lee put in the same quick ratio they have (12.5:1 I think) but it doesn't have the feel. Sounds like it could be the torsion bar.
11-18-2009 #4
