Results 1 to 20 of 22
11-12-2009 #1
68 firebird w/ 600+ hp whats the best way to go
need help figuring out what trans, stall converter, mods, etc.. that will hold up with a 461 stroker in my firebird.
11-12-2009 #2
Banned
- Join Date
- Aug 2003
- Location
- Orlando, FL
- Posts
- 8,745
As I mentioned in your suspension post, need more information on what your going to do with the car. tehe ideal drag race converter makes a horrific autocross converter, and vice versa.
11-12-2009 #3you'll see when you see the suspension post but for everyone else. its going to be mainly street use with the occasional strip run. i want to try for a 9's second street car.
11-13-2009 #4
- Join Date
- Apr 2009
- Posts
- 113
I think a 4L80E is your best choice. 200-4R is your 2nd choice.
11-13-2009 #5
- Join Date
- Jan 2005
- Location
- Netherlands
- Posts
- 1,012
Chek the post i made on your 461 stroker post i put my you tube clips there 2004r 192 mph performs perfect
11-13-2009 #6ok. what stall coverter should i be running with the 200-4r
11-13-2009 #7Seems to me that a lack of budget would be the only reason to forego the electronic control of a 4l80E in favor of a 200R4. Plus, I would think repeated 9 sec quarter miles (slicks?) will require strength beyond what a 200R4 will provide in the long run.
Jeff K.
69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
11-13-2009 #8check out this link. bowtieoverdrives 700R4 for up to 630 hp street strip. they also have one for strip. http://www.bowtieoverdrives.com/cata...m.php?ITEMID=9
89 Supercharged Saleen 352 rwhp, 93 Mustang LX 347 stroker 420 rwhp daily driver, 78 Firebird, 69 Opel Kadett Rallye ex-SCCA track car..."everyone needs to own a 4-bbl 4 cylinder once"
11-13-2009 #9i was just recommended the 200-4r but if it the 4l80e is alot better ill go with that. what converter should i run with it?
11-14-2009 #10
- Join Date
- Jan 2005
- Location
- Netherlands
- Posts
- 1,012
People like to talk in ecseses al the time!! 4l80 this and bla bla . how manny of them actualy had a PROPERLY build tr2004r in there car with proper cooling and tv cabel set up.
you mostly hear the mythologicel horror story,s from second hands and ore from people who instaled them wrong ore build them thereselfs. plenty of 4l80e transmissions who brake as wel...
I have a very small bisenis and our slogan is
""we test the crap out of the parts we sell""
our car is a demo car and we trash the thing. trying to make a point!!its actualy making quiet a name for itself.
if i would have belived al the horror storys, then my engine would have blown up useing the comp cam magnum roller TIP rokkers reving them to 6200 rpm, my tr2004r would have ecsploded in sutch a way that my car would have broke in 2 .
the horse power torque ratings on these Bowtie overdrives are based on the strip grip. im driving my car the same way as transamguy79 whants to do.
the tr2004r can be beefed up to take lots of horse power, but at a sirten level the prize wil be so high that your beter of buying a big and heavy 4l80e .. WHO IS STRONGER FROM THE BASE
my level 3 is build for 630hp/torque. im upgrading it to 730 hp for a aditional 800usd. in that price range a 4l80e would be a beter choice, but not beacuse the tr2004r cant be strong enoughf to take it
this little light tr2004r is doing a perfect job! and beter then i ever askt for.
No beter feeling when you manual use that Hurst quarter stik pistol grip shifter going up and douwn the gears with this mecanicel transmission . and beat the crap out of a Auston Martin vantage at 192mph!!!!, mabey im old fasion but no peddle shifting ore fansy computer for me on the stearing wheel!!.
if i would whant al that kind of stuf il buy a porshe ore a ferrari!!ORE the Auston Martin
I do apresiate and use al the mecanicel afthermarked stuff!!.
i gues thats why my car is called a "STREET FIGHTER""
PS i drive a 2400 SD stal converter changing to a 2600 ED converter with the new engine
11-14-2009 #11
- Join Date
- Apr 2009
- Posts
- 113
The problem with the 200-4R is, that at the 600 HP/TQ level it is a $2000 transmission. It requires several billet components and a deep pan that add to the price.
The 4L80E comes in about the same price but it is inherently strong.
Electronic controls are a good thing. Tuning shift points and shift feel by punching a few keys is a pleasure compared to pulling the pan off, dropping the governor and possibly valve body to get it.
11-14-2009 #12
- Join Date
- Jan 2005
- Location
- Netherlands
- Posts
- 1,012
http://www.bowtieoverdrives.com/cata....php?ITEMID=13
http://www.bowtieoverdrives.com/cata...php?ITEMID=651
Jake besides that both Transmissions need converters and the other parts the 4l80e needs a compu shift ad a exstra 1000$$ witch makes it 1500 usd diferens is pretty big if you ask me.
i dont cal that evenly priced!!. as for the elec stuff as i stated above didnt need it beating up one of the modern greats. its a personal thing.
11-15-2009 #13
- Join Date
- Apr 2009
- Posts
- 113
There are lower cost options than the Compushift for controlling a 4L80E. There is also the full manual VB setup for a 4L80E.
I am very well versed in 200-4R's. I have them running reliably in the low-mid 10's in Grand Nationals. You won't hear of that from Bowtie Overdrives. They can't even figure out that the band in a 200-4R is not a "2-4 band".
However I am a professional performance transmission builder as well as a realist. The 200-4R will never be as strong as the 4L80E. The converter cost is the same.
You can easily spend $400 setting up a TV cable and brackets and lockup on a 200-4R. That is a good part of the way towards a controller that makes life much simpler.
I do these retrofits often. TH350, PG, TH400's being replaced by 200-4Rs, 4L80E's, 700's, etc.
I occasionally even do an AOD or 4R70W retrofit into the Ford stuff.
I make my recommendations based on the experience as a builder as well as installer. I can build a 4L80E for 1500 HP. 700 HP is putting the screws to a 200-4R.
600 is definitely doable, but I wouldn't trust a BTO trans at that level. I would recommend using a unit built by any of the reputable builders in the TurboBuick community.
600 requires a billet forward drum and a pretty serious program with the hydraulics for 3rd gear to be ultimately reliable. Only about 10-12 guys in the States are in this league.
11-16-2009 #14now honestly would i be better off with auto or manual? I can't decide which one i wanna go with.
11-17-2009 #15
- Join Date
- Nov 2009
- Location
- colorado
- Posts
- 3
I also have a 68 firebird, I bored the block.60 over running ross pistons, comp cam but I went with a ford 9in for the back end just because of their strength. I ditched my old tranny because there was no way i would work with the new motor, I was doubling the horsepower, so I now have a tremec TKO 600
11-18-2009 #16
- Join Date
- Feb 2005
- Location
- Indianapolis, Indiana
- Posts
- 337
