View Full Version : LED Headlamps
CapSS92
11-06-2009, 03:35 PM
Hi all, just wondering if anyone has seen these new LED headlamps from Trucklite. http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=64057&langId=-1
They are pricey at about $300 each but if it means I ain't gotta cut up anything to make them fit....
Alex
MCMLXIX
11-06-2009, 05:57 PM
I saw a bunch of them at SEMA today, mostly in Jeeps. I believe they are bolt in. Maybe a little tweak with the factory headlight ring...
CapSS92
11-06-2009, 08:17 PM
Were there any lit up? I wonder how bright they are?
WS6
11-07-2009, 06:15 AM
LEDs are the future so give it a little more time and the prices will come down, the applications will go up, and the performance will go up as well.
jkwalkercchs
11-12-2009, 01:09 AM
seems promising but it doesnt list a lumens output thats the main concern i would have
MCMLXIX
11-12-2009, 02:43 AM
There werent any lit up at the show. Even if there were, it wouldn't give a very good idea of light output. You would need a dark room and a white wall to see the light pattern...
I first saw these lights over on the Harley forum... I think someone had it installed with a camparison photo... I'll go look...
MCMLXIX
11-12-2009, 02:55 AM
http://hdforums.com/forum/touring-models/352089-led-headlamp-2.html
LED on the bottom, Stock with out passing lamps on the top, both low beam:
https://static1.pt-content.com/images/pt/2009/11/led112Copy-1.jpg
Led high beam bottom, stock high beam top:
https://static1.pt-content.com/images/pt/2009/11/led113Copy-1.jpg
Side by side low beam with out passing lamps head on:
https://static1.pt-content.com/images/pt/2009/11/led115-1.jpg
SuperCPA
11-12-2009, 09:22 AM
Thanks for the pics; that does looks promising. Unfortunately, as previously stated their website does not list the lumens rating. However, for comparison, their auxiliary lighting product is rated at 2000 lumens; and, it only uses a fraction (1.4a) of the amps that the headlamps (2.5a/4.5a) are rated for. According to Sylvania's website, the Silverstar lamps range anywhere from 700-1700 lumens depending on the application.
http://www.ledheadlamps.com/81802.html
I'll be watching closely for a release of the 4651 & 4656 sizes.
