View Full Version : LED tails installed, now lights don't work!
mjdwyer23
11-06-2009, 03:27 PM
Hi Folks-
I just installed a pair of Shiny Hiney tails in my 70 chevelle. Everything functioned prior to me touching it (typical). I hooked up black to brown and red to yellow/green, now my tails do not work. Front lights work fine. Ideas? Thanks!
OhioProto
11-06-2009, 06:06 PM
http://shiny-hiney.com/70%20chevelle%20instructions.pdf
it looks like the mount for the housing doubles as the ground...double check that it's a GOOD ground, or just run it to bare metal elsewhere.
mjdwyer23
11-06-2009, 06:33 PM
I grounded the stud with a jumper and no result -- i emailed Wade, we'll see what he thinks. Thanks for your help!
Chicken Coupe
11-06-2009, 07:15 PM
Bulbs are in backwards
How many forums are you going to post the same question to?
mjdwyer23
11-07-2009, 06:43 AM
As many as it takes to get the answer. There are no bulbs to put in backwards.
OhioProto
11-07-2009, 09:45 AM
diodes HAVE to be wired to the correct polarity, as opposed to an actual bulb which can go either way.....do you have 12V to the brown wire?
gmjj13
11-07-2009, 01:04 PM
when i installed my led tails, i ended up having to change the input on the no load flashers where they plug into the fuse block to get everything to work properly. my regular tails worked great prior to installing the led's as well. now everything works like it should...
Rhino
11-07-2009, 03:52 PM
Absolutely correct. A diode (which includes the LED) is a one way street for electricity. From the OP's post I would agree that it's wired backwards.
If you're positive the polarity is correct, have you measured the voltage between the positive wire and the ground you're using?
mjdwyer23
11-07-2009, 04:32 PM
I have confirmed the correct wiring with Wade @ SH. I will be checking the ground and installing the electronic flasher tomorrow, I'll check back in. Thanks!
