View Full Version : fuel pressure mystery
steve g
11-03-2009, 05:26 PM
I thought I was having vapor lock problems because I was stalling out after the car got hot, so I replaced my mechanical fuel pump with a carter electric along with a pressure gauge. I also had previously insulated my fuel lines and added a 1/2 inch wood spacer below the carb. When the car is cold the pressure gauge reads around 7 psi. When the engine gets up to temp, the pressure gauge reads 0. Car is still running, just no reading on the gauge. I have an aftermarket fuel tank without the factory vent tube, so I thought maybe that was the problem. Even with the gas cap off, it still acts the same. Any ideas? I think I'll have to try another gauge to see if it acts the same.
My427stang
11-04-2009, 05:41 AM
Is it a liquid filled gauge? The silicone expands with heat and equalizes with the fuel pressure.
Get an old wiggly style gauge, I bet the problem is gone.
megaladon6
11-04-2009, 02:30 PM
do you have a return line? what size are the fuel lines?
Vegas69
11-04-2009, 02:49 PM
Your car can't run with no fuel pressure. As said the liquid filled gauges are junk for fuel pressure. They will read 0 when hot. Get a non liquid filled and go from there.
jfaria78
11-04-2009, 03:30 PM
or you can say F it and just have fun! That's my vote!
James
steve g
11-04-2009, 04:35 PM
Thanks guys. It is a liquid filled gauge. I guess I'll send it back.
JaySB
11-06-2009, 11:09 AM
You probably just need to run a return line...
