Results 1 to 11 of 11
10-30-2009 #1
- Join Date
- May 2008
- Posts
- 90
In the middle of build....Need Help
Guys,
In the middle of putting the suspension back together with the LS1 front brake conversion on a 67 A-body. I picked up the longer Dorman wheel studs per Tobin, but the diameter of the knurl was way to narrow compared to the regular studs. Anybody know a part number for a 67 A-body extended length wheel studs?
Also, when I compress the a arms and bolt them to the spindle, should I put the shock in at the same time as the spring or bolt everything and put the shock in last?
Tom
10-30-2009 #2try calling goodies speed shop in san jose ca if anyone will know its them, they set me up with moroso ones for the rear.
408-295-0930
1-800-994-0930
10-30-2009 #3
- Join Date
- Jul 2005
- Location
- Marshall , MO
- Posts
- 699
Put the shock in last. just make sure the j nuts are in good shape or risk breaking one and then it is kind of fun to get the shocks back out.
Brad Shepard
69 Malibu
Marshall, MO
11-06-2009 #4
- Join Date
- May 2008
- Posts
- 90
Called Goodies as suggested and good to go! Last question, the original studs were 7/8" long, the new studs are 2 7/8" long. How long should I keep them running the LS1 brakes and Torq Thrust II's?
11-06-2009 #5
- Join Date
- Jan 2006
- Location
- Oregon
- Posts
- 1,773
