View Full Version : Powder coating question
joemac
10-28-2009, 10:02 AM
I have a large stock pot maybe 3 or 4 gallons. Last year I had it too full and the coil burner burnt through the epoxy or whatever it kind of coating it is exposing bare metal.
I like the pot and was wondering if the existing damaged coating could be removed and replaced with a powder coat. What do you think something like this would cost? It might just be cheaper to junk it and get a new one.
Yoda4561
10-28-2009, 10:20 AM
I would be very hesitant to use normal powdercoat on anything that will see a stovetop. The coating on those pots is usually a type of porcelain or heat stable enamel finish.
joemac
10-28-2009, 10:30 AM
What about the ceramic coatings? I'm not sure what the coating was that's on there it is like a dark blue with some type of white or off white spec. I'm thinking it will probably find the junk pile and I will pick up another one.
D Impala95
10-28-2009, 10:39 AM
Any product you find no matter what it is must be food grade. I don't think it's worth your while to have it recoated.
Yoda4561
10-28-2009, 11:43 AM
Yeah, when we accidentally burn a pot like that it usually get sent to second string duty, stuff like deep frying on the bbq grill's burner or into the junkpile.
