Results 1 to 20 of 25
10-26-2009 #1
68 GTO Centerline Wheels on and fronts rub....
Hi all, ordered the Centerline Retro wheels for my 68 GTO. I got the 18x9.5 with a 5.5" BS and mounted 305/45-18 Nitto Drag Radials on and they are perfect. The fronts however are 18x8 with a 4.5" BS and the tires are 245/45-18. The front tires are hitting in the front and the rear and the car is not even driveable the way it sits. That said, it seems like I can go 1" in with no problems at all-my sway bar has been removed for years. So if I am reading this right, I should get the BS changed to perhaps a 5.5" so they move 1" in. Does that sound right or am I missing something? Sucks as I want to drive the car, but it even chewed my new Nitto tire up just going around the block for a test drive.....
Gary
1968 GTO 467 ported Pontiwreck, 9", 5-Speed
2000 Viper GTS, 10Lb SC, Roller Cam, Fully Ported
2008 Viper SRT-10 Coupe, Stock, FOR SALE
2008 Grand Cherokee, 3" OME Lift, armor/winched
2006 Votes thanks to Acorn
10-26-2009 #2I just called Centerline and they were kewl and said that what I ordered should have worked and the most BS they can do on an 8" rim is 5.5". So I will measure tomorrow, but it looks like I will have to go to a 5.5 BS for the front.... Stock brakes, so I can't understand why this is, but it is what it is. They said I could send them back and that it would cost $150 a wheel to change the back spacing, and I have no problem with that, but sucks that I will have more down time.
10-26-2009 #3
- Join Date
- Aug 2007
- Location
- Normal, IL
- Posts
- 258
You need to verify what you are doing. Going from 4.5 to 5.5" backspacing is going to push the wheel out not suck it in.
10-26-2009 #4
